Author Topic: best spark plug for a 68 z  (Read 11519 times)
fireZ
« on: June 01, 2007, 08:11:57 PM »
Anyone have a favorite plug to use in a stock 302 motor.  AC43s seem to foul up terrible even with the carb lean.
1968 Z28 LA Built
LIC # RPO Z28
sam
Re: best spark plug for a 68 z
« Reply #1 on: June 01, 2007, 11:12:53 PM »
I use R44S with no problems. ;D
Jerry@CHP
« Reply #2 on: June 02, 2007, 02:29:18 AM »
AC44s are not made anymore, the easy substitute is Champion J12YC.  Same plug.  This is what we use.
Jerry
fireZ
« Reply #3 on: June 02, 2007, 01:08:43 PM »
Thanks Jerry for the spark plug info. I recieved the 4th edition book this week,great source of information. It is a must if these cars are your passion.
1968 Z28 LA Built
LIC # RPO Z28
« Reply #4 on: June 03, 2007, 03:29:15 PM »
Mine is driven normally around town and on the highway (not raced) with Jerry's distributor setup and 72/76 jetting, and I run AC R45S plugs (also run them in my small-block '67 Corvette), and I have no fouling issues at all (did have some fouling with 44's, and 43's are WAY too cold for normal street use).
x77-69z28
« Reply #5 on: June 03, 2007, 03:55:19 PM »
i run 45s also. no problems
Jerry@CHP
« Reply #6 on: June 03, 2007, 06:41:07 PM »
45s will work for cruising the streets.  Only problem I found with them is in hot weather during the summer if you climb on the rpms a little, there is a good chance that the engine might ping w/36 degrees of total advance (93 octane).  They definately will not foul out as easially as the 44s.  Wanna keep the 44s clean, take 'er up to 7000 rpm once in a while...........now you're talking!
Jerry
fireZ
« Reply #7 on: June 03, 2007, 08:14:39 PM »
There is no better sounding car than a 302 z ringing out at  7000RPM. I remember visiting my Grandpa at a local GM dealership and seeing these 302 cars coming in and out for service and test drives. No better rush for  a young kid.
1968 Z28 LA Built
LIC # RPO Z28
detfox
« Reply #8 on: February 27, 2008, 02:37:58 AM »
It's the same for the 69 302..correct?
Jerry@CHP
« Reply #9 on: February 27, 2008, 02:54:34 AM »
Yes it is,
Jerry
jdv69z
  • 69 RS Z/28 52E
« Reply #10 on: March 07, 2008, 03:52:18 PM »
Jerry
I discovered the Champion J12YC several years back while checking cross referencing charts. I tired 'em and like 'em in my 69 Z. I always have a couple of sets ready to go. Seem to be easy to find as well.
Jimmy V.
Jimmy V.
