Author Topic: wiper cct diagram  (Read 9398 times)
69aus
wiper cct diagram
« on: June 01, 2007, 12:30:41 AM »
Can any one post a circiut diagram or instructions to bench test a 69 Wiper motor ? I have the "in car" test diagram ang "no go". Now would like to test isolated from the dash switch and car.
 I want to prove the thing works by itself  :-\ and prove the problem is then the wiring in the car. Have already replaced the dash switch
Driving me mad trying to get the wipers going  >:(
Thanks in advance
camaromikey
Re: wiper cct diagram
« Reply #1 on: June 01, 2007, 03:09:35 AM »
im not sure if this helps any but i had to go through 3 OER wiper switchs before i got one that worked properly. this post had some good info on how wire one maybe it could help
          http://www.camaros.org/forum/index.php?topic=2152.0
69aus
« Reply #2 on: June 01, 2007, 04:15:02 AM »
Thanks for the reply. I guess what I want is take the wiper motor off the firewall and test it. And by process of elimination find the  >:( problem.
I understand the stand alone pin is 12 V + and the other 2 work ( light blue and dark blue ) work by earthing. I dont wont risk the motor without prior knowledge though  :-\
New 69 wiper motors are not exactly thick on the ground in Australia  ::)
69aus
« Reply #3 on: June 04, 2007, 12:20:19 AM »
HELP, AM DESPARATE  :P
mrdetails
« Reply #4 on: June 05, 2007, 04:18:26 PM »
Do a search for wipers don't work. Their is a post their that may help.
Good Luck:
Sam
69aus
« Reply #5 on: June 06, 2007, 12:05:37 AM »
Thanks mrdetails, regret nothing there on benching testing. the main info I need is which pins to apply 12 volts to check operation.
Mark
« Reply #6 on: June 06, 2007, 01:07:23 AM »
Here you go.  Remeber, the wiper motor is always hot, and it grounds through the switch to the dash.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
69aus
« Reply #7 on: June 06, 2007, 03:31:49 AM »
Thanks Mark
                 Awsome  ;D
Peter
