Author Topic: 67 washer pump  (Read 6114 times)
67l35
67 washer pump
« on: May 31, 2007, 02:43:23 PM »
All the rubber parts in my washer pump are trash and I can't seem to find what I need to rebuild it.  Is there a good source for parts, or somebody that can restore these?
rich69rs
  • LF7/M35/Z22/Z87
Re: 67 washer pump
« Reply #1 on: May 31, 2007, 05:11:45 PM »
Similar discussion - see the following:  http://www.camaros.org/forum/index.php?topic=2206.0
Richard Thomas
1969 RS
dab67
  • 67 SS
Re: 67 washer pump
« Reply #2 on: May 31, 2007, 05:54:33 PM »
Try  www.rickscamaros.com  -- Rick's First Generation
They have listed under wipers and washers some parts and repair kits. Not sure they have what you are looking for.
Good Luck
Dave
WMCC AL
  • WMCC Membership Coordinator
Re: 67 washer pump
« Reply #3 on: May 31, 2007, 06:15:26 PM »
I have checked w/several Camaro Parts Suppliers and have been able to locate some of the seals and rubber parts but not a plunger and plunger seal.  Most of the rebuild kits include the nozzles and "O" rings, and some of the seals.  FYI- The same kits are available through your local NAPA store.
WMCC - Membership Coordinator
67l35
Re: 67 washer pump
« Reply #4 on: June 01, 2007, 03:45:53 AM »
I saw that discussion, but it didn't answer my question  I've also seen the kit Ricks sells and while some of the parts are there, not all.  Sounds like I need to buy the 68-9 pump and live with it.
