Author Topic: Engine lift brackets  (Read 10566 times)
McKenzieDave
« on: May 27, 2007, 09:30:50 PM »
Does anyone have a correct photo of the engine lift brackets on the intake of a 69 327.  I assume all SB cars sould be the same.  Why do you never see these on a "restored" car?  I know this engine had them because they were in the same bag as all other intake hardware and they have two special bolts while missing two normal intake bolts.  Dave
Re: Engine lift brackets
« Reply #1 on: May 27, 2007, 11:38:31 PM »
Dave -
Could you please post a photo of your brackets?  Are there any letters or numbers (i.e. "K", "S", etc.) stamped on them?  Thanks for your response.
McKenzieDave
« Reply #2 on: May 28, 2007, 12:18:17 AM »
Brackets w/bolts.  Dave
McKenzieDave
« Reply #3 on: May 28, 2007, 12:19:14 AM »
And intake.  Dave
Jerry@CHP
« Reply #4 on: May 28, 2007, 12:30:31 AM »
There is also a good photo of the front hook in place in my 1969 Camaro fact book on page 11.  The rear lift hook installs in the very last hole on the passenger's side of the engine.
Jerry
« Reply #5 on: May 28, 2007, 12:38:01 AM »
Thanks Dave -
The front hook (right one in your first photo) appears to be mounted in the second hole from the front on the driver's side of the engine per Jerry's book.
McKenzieDave
« Reply #6 on: May 28, 2007, 01:17:44 AM »
Thank you gentlemen.  I had just picked up that very book when I decided to check for responses.  Dave
4b316
« Reply #7 on: June 10, 2007, 12:39:22 PM »
Some of them did have numbers stamped into them.K,M,S is some of the letters I have seen.I have a natural finish set that has like a little horseshoe stamped in it.Have a "S" set on e bay
rich69rs
  • LF7/M35/Z22/Z87
« Reply #8 on: June 11, 2007, 01:40:38 AM »
Did the brackets always stay on the engine after the car was finished?
Richard Thomas
1969 RS
x77-69z28
« Reply #9 on: June 11, 2007, 03:43:17 AM »
yes
