Author Topic: 1967 SS 350 7N163718  (Read 12413 times)
Pgr33n
« on: May 23, 2007, 02:38:55 PM »
Just pick up a 67 camaro 6 cylinder car with a 1967 350 SS motor in it.  If someone out there has the mating car let's talk.
Pat
Sorry, here is thst info.
Motor 3892657 front pad VI228MS date code L286
Heads 3890462 L216
Intake 3905393 H46
« Last Edit: May 23, 2007, 07:50:03 PM by Pgr33n »
Re: 1967 SS 350 7N163718
« Reply #1 on: May 23, 2007, 04:34:02 PM »
Hi Pat -
Would you please post the following info?
1) The engine assembly code.
2) The block casting number.
3) The block casting date.
Thanks in advance.
dab67
  • 67 SS
« Reply #2 on: May 23, 2007, 05:17:22 PM »
definetly like to see those numbers!
Dave
Pgreen
350 SS MOTOR
« Reply #3 on: October 11, 2018, 03:05:18 PM »
Just pulled a 1967 350 SS motor out of my 67 RS convert. Nice running motor, I replace it, to put the original 327 motor back in the car.
Motor numbers:
3892657
vin 7N163718
FRONT PAD: VI228MS
BLOCK DATE: L266
HEADS:
462
HEAD DATE: L216 both heads are dated the same.
Can someone here see if there is a match in your database.
« Reply #4 on: October 11, 2018, 03:39:22 PM »
Since you originally posted the numbers back in 2007, I went ahead and merged the two threads together. And no, the car isn't in the database.
Pgreen
« Reply #5 on: October 11, 2018, 04:07:15 PM »
Thank's
RichSS2006
« Reply #6 on: December 27, 2018, 09:59:53 PM »
Here is the Pad Stamp from Facebook.
69 X22 L78 M21 10-10
69 Z11 L48 M20 50A
VINCE Z28
« Reply #7 on: January 06, 2019, 04:59:26 AM »
FYI For sale in Portland, Oregon. CL 3200.00
