Author Topic: 69 4 drum power booster tag and 2gv carb spring  (Read 2241 times)
KevinW
« on: March 13, 2025, 09:46:37 PM »
Hey all, just some random questions for an early build 69.  I am pretty sure the little paper tag on booster check valve is CB for power disc, but what tag would have been used for 4 drum power brakes?
Also, what specs/color was the throttle return spring for a 2-bbl? Anyone with a pic? Thanks!
Re: 69 4 drum power booster tag and 2gv carb spring
« Reply #1 on: March 14, 2025, 04:24:01 AM »
It's CU for power discs, CG for power drums.
KevinW
« Reply #2 on: March 14, 2025, 12:11:54 PM »
thanks Kurt!
KevinW
« Reply #3 on: March 15, 2025, 03:49:19 PM »
Ok, here is my 1st attempt at the paper booster tag. font is pretty close IMO. I kinda guessed at the size (7/8"x 1 1/4") seem right to me.
I hope to dial in my 2GV spring options and post another pic as soon as I locate a spare coil bracket :sigh:
Here is a pic of the check valve tag I made.  How close did I get it?
KevinW
« Reply #4 on: March 15, 2025, 03:52:00 PM »
Kurt, btw, my car came with 4 drum non-power of course.  I added the power MC/booster for safety. Still does not stop as well as discs.  Oh well.
KevinW
« Reply #5 on: March 15, 2025, 05:30:13 PM »
OK, for the carb springs, I have two candidates (after I found my bracket).
I skinny one and larger one.  Which is more correct? Thx
rich69rs
  • LF7/M35/Z22/Z87
« Reply #6 on: March 15, 2025, 07:14:33 PM »
The drums new are 9.5” inside diameter with a discard diameter of 9.560”.  (Some sources say 9.590”.)
For the drums to work effectively and as designed it is absolutely necessary that you:
•  don’t exceed the 9.560” allowable inside diameter (so that the shoes don’t have to move excessively
•  on the front brakes - install the larger (longer and somewhat wider) shoe to the rear and the smaller shoe to the front
• ensure that you have the correct residual pressure valves in the master cylinder outlet ports.
Richard
« Last Edit: March 15, 2025, 08:10:40 PM by rich69rs »
Richard Thomas
1969 RS
rich69rs
  • LF7/M35/Z22/Z87
« Reply #7 on: March 15, 2025, 07:19:54 PM »
My ride has the base 327/210 hp engine which has the small (1-1/4”) bore Rochester 2GV 2 Bbl.  The return spring on mine is more like the “skinny” one you show.
Richard
« Last Edit: March 15, 2025, 07:42:55 PM by rich69rs »
Richard Thomas
1969 RS
KevinW
« Reply #8 on: March 15, 2025, 07:56:48 PM »
Thanks Richard!  Skinny spring is what I will use!
On the brakes, I pull off the drums every spring to give them a clean and adjust.  I will look into what you posted. thx
David K
  • Dr. Longblock
« Reply #9 on: March 15, 2025, 11:17:36 PM »
Upgrade to front disc.
KevinW
« Reply #10 on: March 15, 2025, 11:37:39 PM »
Funny!  I have thought about it, but with my Drum only rims, I would have to swap those out too. Unless I got the Right stuff 14" drum to disc kit.  Money, Money, Money :)
GMAD_Van Nuys
« Reply #11 on: March 16, 2025, 04:42:22 PM »
I don't see a problem using drum brakes on your Camaro as properly maintained, they are okay for normal street driving.
KevinW
« Reply #12 on: March 16, 2025, 06:13:40 PM »
Thx!  Yes, I inspect/clean/adjust them every spring.  And plan my stops.  Twice I had panic stops and the brakes lockup and fade quickly!  but I stay as alert as possible!
Another 2GV mystery: I have two 2GV carbs.  Exactly the same except the vent cover is slightly different.  One has a full cover, the other a cover with a cutout.  I looked at the CRG report  http://www.camaros.org/carb.shtml and the pics of 68 and 69 had the cutout, but the 67 was not in frame. ps, I have only one carb tag 7029110 CH from 68, but not sure which carb it came off of.
KevinW
« Reply #14 on: March 16, 2025, 08:38:11 PM »
Richard
Richard, so what does a factory residual pressure valve look like?  I pulled the brass seat out of an old drum master cyl (rear port) and there was nothing there!  Now I am confused.
