Author Topic: reproduction body or other orginal body  (Read 245 times)
gary
« on: February 18, 2025, 10:40:42 PM »
Hey guys and gals, I'm needing to know what you think I  should do. I have a 1968 Z/28 with lots of options and all orginal numbers with paper work and protecto plate. The body is so bad that I would have to change nearly every part. Do I buy a repo
body or rebuild this one or I also have a 68 body that has NO rust. What do you think?  Thanks for you input. Gary
The good body is about 4 months different in build date.
mls68z28
Re: reproduction body or other orginal body
« Reply #1 on: February 19, 2025, 12:01:22 AM »
Can you do most of the rust work?
Mitch,1968 Z28 03C Norwood,03/18/68,Seneca Falls NY,Z/28 Emblems.Purchase 05/04/78
x66 714
« Reply #2 on: February 19, 2025, 01:21:42 AM »
Some pictures would be helpful. The repop bodys arer't exact. Using the rust free body would meen changing VINs....maybe. Maybe grafting the 2 together might be an option. I would try to retain as much of the original car as possible. But then again, I live in southern Arizona & don't really see these problems...Joe
gary
« Reply #3 on: February 19, 2025, 12:29:05 PM »
yes I can do the rust work. Not much of the body can be used. Thanks for your input Gary
