Author Topic: Holes in Dash  (Read 597 times)
Brew14u
Holes in Dash
« on: February 12, 2025, 11:06:58 PM »
I took the dash pad off of my 1969 Camaro and was surprised to find 17 holes that appear to have been drilled in the metal dash under the dash pad.  The holes are spaced apart, generally in two rows, but not precisely spaced.  They appear to have been drilled from the inside of the dash to the outside based on the burr that remains on some of them.  They are not the holes used for the dash pad mounting studs.  I've had several 1969 Camaros, but never noticed anything  like this before.  I doubt they are factory.  Has anyone else seen anything like this?  Any idea what purpose they may have served?  I doubt it matters, but mine is a standard interior.
Brew14u
Re: Holes in Dash
« Reply #1 on: February 12, 2025, 11:08:21 PM »
Only one picture made it through with the original post.
camaronut
Re: Holes in Dash
« Reply #2 on: February 14, 2025, 05:33:10 PM »
Looks like someone screwed the dash pad onto the metal dashboard from behind instead of using the correct mounting tabs.
Brew14u
Re: Holes in Dash
« Reply #3 on: February 14, 2025, 08:08:51 PM »
I hadn't thought of that, but you may be right.  Thanks.
Brew14u
Re: Holes in Dash
« Reply #4 on: February 17, 2025, 09:17:33 PM »
Good call, I think you are right.  From the inside out, it looks like the head of the fastener deterred the rust.  I hate that someone did this to an otherwise unmolested camaro.
