Author Topic: Tracking down electical issue  (Read 759 times)
1967SS-Dave
  • Living An Old Mans Dream
« on: February 01, 2025, 12:34:22 PM »
I just bought a 67 Camaro SS-350 that has a frame off resto completed a few months ago. The car looks amazing! Every bolt and wiring harness was replaced new. But I have several electrical issues I am working out that it seems they never finished or have wrong. The car was converted to a SS-396 Clone with a 454, and a console with the gauge package was added, also tach in the dash pod.. Car was originally a 4speed on the floor. with no console or gauges.
 1. The RED FUEL light in Dash Pod is always on even with a full tank, the fuel gauge in the Console Gauge Pod works correct.
 2. The Tach is not working but is hooked up to the HEI Tach cap port
 3. Temp gauge in the Console Gauge Pod is not working, but is hooked up to the temp sensor on the DRV side of the block.
 4. Battery Gauge in the Console Gauges does not work.
 5, Oil Pressure gauge does work.
Dave
1967 SS-396 Marina Blue (Clone)
05C-67-12437 NOR121785
717-Z/W/2L/3K/4P/5Y
rich69rs
  • LF7/M35/Z22/Z87
Re: Tracking down electical issue
« Reply #1 on: February 01, 2025, 03:43:17 PM »
I’d start by checking ground issues for #3 & 4.
Link beliw has installation instructions for the gauges.
http://www.camaros.org/forum/index.php?topic=19153.msg173331#msg173331
If you simply do a search (box - top right corner) for gauges or HEI, you will get many posts you can check.
Richard
Richard Thomas
1969 RS
