Author Topic: Radius Rod Torque Specs  (Read 4163 times)
Daral
« on: May 17, 2007, 03:28:06 PM »
Does anyone have the torque specs for the radius rod bolts and bracket.  I have looked everywhere. I even have the Dealer Service Technical Bulletin 67-T-30 for "Radius Rod Installation" (Thanks Daniel). It lists all the parts and describes the installation but doesn't give any torque specs. If no one has this, I guess I will torque it to 50 ft lbs; the same as the rear spring shackles. I have torqued the bolt and nuts for the mounting plate to 25 ft lbs; the same as the bracket for the leaf spring perch. Does that sound reasonable?
67 RS/SS 350
