Author Topic: LA built Camaros rear leaf spring black paint  (Read 635 times)
hugrz28
« on: January 09, 2025, 05:21:47 AM »
I'm soliciting input from owners of LA built Camaros. My 1969 Z/28 (March) has the original leaf springs which are painted black (satin) and not partially but complete on both sides. I've been in contact with other LA built Camaro owners (1st Gen.) and they report the same thing. I believe that John Mello in a previous post noted that the gas tank with some over spray on the rear springs were found to be black also. Looking forward to any input.
Thank you,
Dan
Re: LA built Camaros rear leaf spring black paint
« Reply #1 on: January 09, 2025, 01:09:41 PM »
Not only the springs and fuel tank, tailpipes also. A bud had an April-built survivor VN Z/28 with original painted tail pipes.
The photo is from the Petersen publishing archives. The car was built at VN September 30, 1968, and featured in the January 1969 issue of Hot Rod.
« Reply #2 on: January 09, 2025, 03:35:29 PM »
Of the cars I have seen in person, the LA plant was a lot more liberal with paint. They have paint in some areas that Norwood cars do not. And that seemed to have provided better protection for longevity.
hugrz28
« Reply #3 on: January 09, 2025, 06:04:33 PM »
Thank you to both of you for your input. It's been a journey learning about the differences of how LA built Camaros as opposed to Norwood. The black paint on the rear leaf springs has baffled me for years. With far fewer Camaros built at LA, I'm sure I will run into more items that are LA specific.
Thank you,
Dan
HOT3O2
« Reply #4 on: January 09, 2025, 09:01:46 PM »
If there isn’t one already I’d like to see more info or a thread on the known differences between the Norwood and Van Nuys built Camaros.
Rick
69 RS/Z28
169INDY
« Reply #5 on: January 10, 2025, 04:35:12 AM »
^^ Right on a Throw Down LA -vs- Nar'wood
Sorry Us West Coasties are in the Minority' 75/25 split or so.
Hole Piercing to Bolt Directions and More ?
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
hugrz28
« Reply #6 on: January 10, 2025, 04:38:27 AM »
I think that's a great idea! We would probably need to start a new post (blog) and this might be the first entry. Maybe Kurt could help us set something up.
Dan
« Reply #7 on: January 10, 2025, 12:45:45 PM »
Jack assembly, trunk spatter paint, foam pads under cowl vent grille, motor mount bracket fastener position. All VN VIN tags seem to be black. Through the end of October 1968, Norwood tags were color-coordinated. Some VN Z/28s w/o vinyl top have the shorter rear stripes. Haven't seen a VN build with sound deadener inside the rear quarters.
I'm sure there are others.
HOT3O2
« Reply #8 on: January 10, 2025, 03:57:47 PM »
Thanks William, That sure is a good start.
Rick
69 RS/Z28
hugrz28
« Reply #9 on: January 10, 2025, 06:13:38 PM »
Thank you William, I've learned some new details I was not aware of. I plan to add a few more today and look forward to feedback.
Dan
x66 714
« Reply #10 on: January 10, 2025, 10:41:20 PM »
For 1968, how the striping was done under the spoiler & the fasteners that attach it to the lid.....Joe
hugrz28
« Reply #11 on: January 11, 2025, 02:23:13 AM »
On 69 Z/28's built at LA, the stripe color that (in my case is dover white) continues to the edge of the cowl. I've spent mant years observing how this was done. In general, LA cars have a soft edge tape line with no overspray onto the firewall. What I mean by a soft edge tape line is that the stripe termination is not perfect. I'm going to look through my picture collection and post a few examples. Is there anyone out there that has noticed this detail as well?
Dan
hugrz28
« Reply #12 on: January 11, 2025, 05:00:51 PM »
I’ve enclosed a picture of a LA built (Feb. 69) Z/28. If you zoom in you can see the soft tape line of the Dover White stripe at the cowl.
hugger69z28rs
« Reply #13 on: January 12, 2025, 07:40:23 PM »
The gas tank and parts of the undercarriage (mainly floor pans and tunnel area) on my car has definitely been undercoated and it appears factory. Exhaust has been changed. VN 5A car.
hugrz28
« Reply #14 on: January 13, 2025, 01:05:20 AM »
Where was the selling dealership?
Dan
