Author Topic: 1969 Radio delete /factory 8 track  (Read 4998 times)
john302
« on: December 16, 2024, 01:25:45 AM »
Would a 69 radio delete with a factory 8 track have engine grounds and inner fender to frame grounds? Voltage regulator noise suppressor? Thanks
David K
  • Dr. Longblock
Re: 1969 Radio delete /factory 8 track
« Reply #1 on: December 16, 2024, 01:57:00 AM »
I do know this, there is no such thing as a radio delete. If the order box is not checked ,the radio does not get installed.
KevinW
« Reply #2 on: December 16, 2024, 12:30:05 PM »
Also, I don't think you could have ordered an 8-track without some type of radio, probably a am/fm stereo version.
« Reply #3 on: December 16, 2024, 08:28:44 PM »
In the AIM, U57 pg. A5 depicts the wiring connection for an under dash 8-track on a car built without a radio.
I have no idea why a car w/o radio would need the ground straps. Was it built with them?
« Reply #4 on: December 16, 2024, 08:34:10 PM »
Nope, the tape player could be ordered by itself all three years.
John,
What's the AIM show for grounds in the U57 section? I don't have the AIM handy this second.
KevinW
« Reply #5 on: December 17, 2024, 01:21:00 PM »
Good to know! thx
CantRepeat
« Reply #6 on: December 18, 2024, 10:57:21 AM »
John,
Looking through the 67 AIM, U57 A1-A4 there are no ground straps listed. I assume since it's not using radio frequencies there wouldn't be any interference from other sources.
-Tim
john302
« Reply #7 on: December 23, 2024, 12:02:22 AM »
Just looked at the firewall and I see no holes were the ground straps would mount. Also the voltage regulator should not have a noise suppressor?
« Reply #8 on: December 27, 2024, 07:02:46 PM »
No. Though I'm a bit surprised by that....
