Author Topic: 69 Z28 06A battery cables side post Y77  (Read 3056 times)
DONCZ28
« on: December 14, 2024, 07:11:42 PM »
My O6A Z came with a positive battery cable #3297683AR, same part number as in the AIM. I acquired an #3297684 AS. The 84 also looks correct. Original Delco eye cables. What goes here ?
Danzo
Re: 69 Z28 06A battery cables side post Y77
« Reply #1 on: December 15, 2024, 12:03:00 AM »
DONCZ28
« Reply #2 on: December 15, 2024, 02:53:06 PM »
Doc, Is it possible that the 84 supercedes the 83 ? Aim shows 6297683 . Purchased my car in 82 and it had both original style cables. Can't remember if the positive cable had the 5/16"  bolt . The replacement battery had 2  3/8"  bolts .
« Reply #3 on: December 16, 2024, 04:39:07 AM »
I have now seen one set of AU/AR cables - on a later 307 car.
There were Z's built before and after that 307 car and they had AS/AV cables.
I don't have later 307 cable data, so it is hard to make any conclusions.
DONCZ28
« Reply #4 on: December 20, 2024, 05:51:22 PM »
My 680 negative ,and 683 positive cables ,came on my 06A 69 Z when purchased in 1982. The AIM shows these numbers. The 84 is exactly like the 83 but much thicker . The 84 must have superceded the 83. Also the repro cables show 680 N and 683 positive.
