Author Topic: 1969 ZL2 Undehood Insulation  (Read 5001 times)
hugrz28
« on: December 01, 2024, 02:06:32 AM »
I'm wondering if anyone might have an underhood insulation pad that they could share a picture of. I'm curious about the color of an original underhood insulation pad. I've seen many used, dirty originals and they appear to be a flat black in color. I suspect that it my be from years of dirt and grime (oil) but thought I would solicit input from the experts. Looking forward to any input you might have
Thank you,
Dan
Re: 1969 ZL2 Undehood Insulation
« Reply #1 on: December 01, 2024, 01:33:38 PM »
This photo was posted online many years ago, now gone. Said to be taken shortly after delivery.
hugrz28
« Reply #2 on: December 01, 2024, 08:08:10 PM »
Thank you William for posting the picture! To me it looks like there are black strands in the fiber weave that make it appear a little darker. I hope to get a picture of a friends original underhood insulation. If I do, I will certainly post it here.
Dan
« Reply #3 on: December 02, 2024, 04:27:17 AM »
Here is mine OFF the INDY Pacer (LOS)
Disposed.
hugrz28
« Reply #4 on: December 02, 2024, 06:19:37 PM »
A picture of an early take-off original underhood insulation pad from a 1969 Indy Pace Car. it has been lightly cleaned with simple green and put in storage for years.
lynnbilodeau
« Reply #5 on: December 22, 2024, 03:57:48 PM »
Guessing the point is to see if there is a decent repop?
Is there?
camaronut
« Reply #6 on: December 22, 2024, 10:59:19 PM »
I bought a reproduction molded underhood insulation a few years ago and its nice.
Pretty sure it was from Camaro Central, but they are available at all the major Camaro parts vendors.
Shipping won't be cheap, and what condition it ends up like is hit or miss.
hugrz28
« Reply #7 on: December 23, 2024, 03:49:36 AM »
Yes there is a very nice reproduction underhood insulation made by REM. The only problem is they are very thick and really don't compress. When you try to install the clips (original or reproduction), they will at a minimum crack or break completely. I have a couple of ideas on how to possibly make the clips install without breaking but I'm also soliciting any ideas form the group at large.
Dan
boomer632
« Reply #8 on: December 23, 2024, 12:21:21 PM »
Dan
I have the REM installed on my ZL2. Its pretty rigid and thick. Almost like a woven fiberglass material. I cant get the OEM repro clips to lock into the hood either. The clips without the 4 holes do secure well, but I would prefer to have the factory looking ones installed. Theyre still in bag. Waiting to come across a good solution to this problem.
06A X66 711 57 57 L78 M22 BU
camaronut
« Reply #9 on: December 24, 2024, 12:25:36 AM »
Dan
Had the same issue......you can use the original clips (there are decent repros too) by cutting a small piece of black small thickness O ring, maybe a 1/8" long and keep it handy.  Next, put the clip into the hole.  While it's in the hole, use a small screwdriver and stuff the rubber O ring piece in between the part of the clip that goes into the hood to spread the teeth apart to keep it in place.  Works all the time.
You didn't say anything about taking them out..........lol.
