Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
67-69 Disc brake shield plating
« previous
next »
Print
Pages: [
1
Author
Topic: 67-69 Disc brake shield plating (Read 3030 times)
john302
Member
on:
November 29, 2024, 05:35:52 PM »
Were the original disc brake shields galvinized or dull cad plated ? looked at some original ones and they looked dull silver cad plated. Thoughts ? thanks
Tweet
Logged
Hero Member
Re: 67-69 Disc brake shield plating
Reply #1 on:
November 30, 2024, 05:01:27 AM »
My thoughts are they were Galv. based on low mile and hidden crevice non exposed portions observed. The color, grain and mottled look convinced me.
What does the Judging manual(s) specify & Jerrys Books recommend as coating ??
The interesting question has been were they flat Sheet metal galv prior to stamping or dip galvanized after pressing. I believe that the GM spec was for Galv (vice Electro Plating) since it has a better long term rust performance than zinc or cad plating based on the duty of a disc brake rotor splash (water) protection.
I have found platers Hostile to hobbyists, and never even found one avail to perform Low volume (Hot or Cold) Galvanized Auto Parts, so I have settled on Brite Clear Zinc as my only option.
https://www.yenko.net/forum/showthread.php?t=165669&highlight=Galvanized
Logged
buenymayor
Member
Reply #2 on:
November 30, 2024, 08:02:51 AM »
IIRC, Jerrys book states the dust shields were silver dichromate plated, and the caliper mounts were gold dichromate plated. Steering knuckles, spindles, and tie rod ends were bare cast iron.
Logged
john302
Member
Reply #3 on:
November 30, 2024, 10:26:51 PM »
I think Jerry put that in has book because its the only plating available ?
Logged
JohnDS
Newbie
Reply #4 on:
February 01, 2025, 02:18:28 AM »
The disc brake dust shields were most definitely stamped from galvanized metal originally.
At least from what I've discovered on '67-'68.
John
Logged
Print
Pages: [
1
« previous
next »
Originality
