Author Topic: Ignition coil  (Read 15784 times)
Danzo
Ignition coil
« on: October 12, 2024, 11:11:53 PM »
Need a coil for a 69 Z. Are there any new ones out there worth buying or should I try and find a 55 year old original?
Ty, Doc
GMAD_Van Nuys
Re: Ignition coil
« Reply #1 on: October 13, 2024, 03:46:08 PM »
Prior CRG discussion on ignition coils used on the 1969 Z28:
http://www.camaros.org/forum/index.php?topic=11755.0
Danzo
Re: Ignition coil
« Reply #2 on: October 13, 2024, 04:49:23 PM »
Thank you for that link but I am looking for input on whether the repop ignition coils are any good or do I search for an original one.
Doc
Re: Ignition coil
« Reply #3 on: October 13, 2024, 05:48:33 PM »
Coils can be tested to see if they are good.
I sold one earlier this year, it was the 270 - correct for the ZL2 hood.  I wasn't sure if it was any good. Sold it to a guy, he had it tested and it was good. I don't have any extras at this time.
wisemanz28
Re: Ignition coil
« Reply #4 on: October 13, 2024, 09:55:41 PM »
I just bought a 270 coil , they are hard to find and an original one is expensive.
camaronut
Re: Ignition coil
« Reply #5 on: October 15, 2024, 12:30:45 PM »
They were being repro'd for awhile - then no more.  Wonder why.
mls68z28
Re: Ignition coil
« Reply #6 on: October 15, 2024, 11:41:42 PM »
Is this what you are looking for? Mitch
Mitch,1968 Z28 03C Norwood,03/18/68,Seneca Falls NY,Z/28 Emblems.Purchase 05/04/78
Danzo
Re: Ignition coil
« Reply #7 on: October 16, 2024, 01:42:48 AM »
PM sent
Doc
Re: Ignition coil
« Reply #8 on: October 16, 2024, 03:53:08 PM »
For the Sake of Conversation, it is Not just the Coil, but the accompanying Bracket that configures a C. I. Coil set up, the Angle of the Bracket is set back greater in an effort to "Clear' the Large Diameter air cleaner body. - Correct?
(Re. I used the Tip-Trick) from Chick to clear a 68 C.P. Air cleaner.
camaronut
Re: Ignition coil
« Reply #9 on: October 16, 2024, 05:28:16 PM »
That's how I always understood it.  http://www.camaros.org/engine.shtml#coils
Danzo
hugrz28
Re: Ignition coil
« Reply #11 on: October 17, 2024, 02:05:21 AM »
1969 application beyond 9/68 would be 270 B-R.
Dan
Re: Ignition coil
« Reply #12 on: October 17, 2024, 11:57:46 AM »
Dan
Only the 3,500 or so Z/28s built with the ducted hood used the 1115270 coil & bracket assembly.
Z/28s built with the standard production hood used the 1115298 coil & bracket assembly.
Petes L48
Re: Ignition coil
« Reply #13 on: October 17, 2024, 04:26:44 PM »
Would that 270 coil The Parts Place sells (no dash between the B and R) be correct in appearance for a 67 L48?  Did anyone have thoughts or experience on the quality of these repop coils?
Re: Ignition coil
« Reply #14 on: October 17, 2024, 07:34:46 PM »
As William stated - the 270 coil is only technically correct for the 1969 Z28 with ducted hood.
