Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
Trunk mat tear repair
« previous
next »
Print
Pages: [
1
Author
Topic: Trunk mat tear repair (Read 11015 times)
70z28lt1
Member
on:
September 11, 2024, 05:15:21 PM »
Just wondering if anyone has a good way to glue-weld a tear in an original trunk mat? I have reinforced the back of it with the Flex-Seal rubber tape which does stick well, but the crack is still pulls open a bit.
Tweet
Logged
Sauron327
Hero Member
Re: Trunk mat tear repair
Reply #1 on:
September 12, 2024, 11:35:28 PM »
If it's pulling away then it's not sticking well. Try plywood seam tape. It's very sticky.
Logged
70z28lt1
Member
Reply #2 on:
September 13, 2024, 12:00:41 PM »
Thanks for the reply.
I think the problem is it is on a corner right where the trunk floor pan bends up to the sides. The flexible rubber tape on the back is sticking well enough, but is flexing a little and so the tear opens up a bit. The tear itself needs to be bonded together and I'm not sure what kind of glue or bonding system to use I'm tempted to use some type of heat but don't want to make a melted mess of things. i would of course like to make it as invisible of a repair as possible.
Logged
MO
Hero Member
Reply #3 on:
September 14, 2024, 05:05:04 AM »
I think with the flex seal tape already on, you're going to be limited to possibilities. I doubt you'll be able to remove it, but you might be able to slice it and try to get the gap closed and retape it.
Logged
rlw68
Member
Reply #4 on:
September 22, 2024, 12:19:52 PM »
I would try Plastidip VLP on a tear like this.
https://plastidip.com/product/vinyl-leather-repair-vlp/
Repair video
https://www.youtube.com/watch?v=b9I6iwiXRFk
Logged
Rob
1969 02D Norwood Z/28. Lemans Blue 715
Print
Pages: [
1
« previous
next »
Restoration
