Author Topic: Turn signal cancel cam  (Read 7096 times)
TRLAND
« on: September 07, 2024, 03:35:00 PM »
Does anyone know where to get a turn signal cancel cam that will function correctly on a 67 with tilt column? It has the Boyne style switch (red) which uses a cancel cam that has the 2 bumps wider apart than the style that is sold as a reproduction. I can’t find it anywhere and I’ve tried to repair mine with epoxy to fix the cracks but it looks like the plastic is too far gone.
Mike in Northern Illinois
1967 RS 327
GMAD_Van Nuys
Re: Turn signal cancel cam
« Reply #1 on: September 07, 2024, 06:06:44 PM »
rare396bronze
« Reply #2 on: September 07, 2024, 06:12:57 PM »
GM part number is 399294!
TRLAND
« Reply #3 on: September 07, 2024, 08:19:28 PM »
This turn signal cancelling cam is supposed to be for a 1967 Camaro with a tilt steering wheel:
https://www.classicindustries.com/product/all-years/pontiac/firebird/parts/CM5149.html?srsltid=AfmBOoqt4WjPCrnHK7zXkVcKT6yuJUKBif26M9zYlz4eSQiFYqFQX24Mwe4
Thanks, but that is the wrong one for the Boyne style switch. Those plastic bumps near the top are too close together.
1967 RS 327
TRLAND
« Reply #4 on: September 07, 2024, 08:25:22 PM »
Thanks but searching for that part number also finds the wrong style. I think those fit the Delco style turn signal switch. I’m starting to conclude that nobody reproduces the one I need.
1967 RS 327
CantRepeat
« Reply #5 on: September 07, 2024, 09:11:49 PM »
This one has them a little bit farther apart.
https://www.ebay.com/itm/154018314559
-Tim
GMAD_Van Nuys
« Reply #6 on: September 07, 2024, 09:46:02 PM »
Seller on eBay has turn signal cancelling cam, part number 399297:
https://www.ebay.com/itm/362962859725?chn=ps&mkevt=1&mkcid=28&srsltid=AfmBOopiQ2RIktxhozUUoxdqcBEgVImLCNvO3B6ZVLSOM1yFJrIrGaBtB9E
You could ask the seller for additional photos and to measure the distance between the two bumps.
TRLAND
« Reply #8 on: September 08, 2024, 08:56:02 PM »
The only number on mine is 512-4. When I get the new switch, I’m going to try getting a repro to work. The recess for the steering wheel compression spring is on the opposite side, the post that holds the horn contact is too long, and the canceling tabs are in the wrong position. But I think it might just work with some simple modifications. The exact version I have doesn’t seem to be available. My original may also still work if I can use enough epoxy to keep it from falling apart.
1967 RS 327
TRLAND
« Reply #9 on: September 09, 2024, 07:27:41 PM »
Someone on Camaros.net replied with the part number GM part 3901618 which appears to be the correct part for my application and appears to be available at some of the Corvette vendors. But, I got the new Boyne style switch before I saw that post and I was able to get it all working again using the incorrect cancel cam I bought by cutting the horn contact post to the correct length and putting the steering column compression spring under rather than over the cam. As expected the right turn cancels sooner than the left but that isn't a big deal and may be by design a soft right turn like merging onto a highway should cancel early anyway.
Anyway, it all works again and is like new! Thanks to all who responded.
1967 RS 327
