Author Topic: Water pump  (Read 10644 times)
HustleRussell
Water pump
« on: August 23, 2024, 11:11:13 AM »
This is the water pump that was on my ‘69 L48 SS
when I purchased it in 1995. The casting numbers
don’t fit the profile in the CRG report. Can anyone
tell me how to decode this? Thanks
Russ
68 RS
69 SS
Re: Water pump
« Reply #1 on: August 23, 2024, 10:24:20 PM »
Don’t know how to decode, but it’s not original.
Numbers in the report are correct. We wrote that in 2015.
buenymayor
Re: Water pump
« Reply #2 on: August 24, 2024, 09:17:03 AM »
Agreed. That number format isn't a GM number, especially from that era.
boomer632
Re: Water pump
« Reply #3 on: August 24, 2024, 12:09:37 PM »
Assembly line pumps with date codes are readily available on interweb.
My case was a bit different. I have an 06A with 396 and the switchover from the 065 the 811 casting occurred right before my car was  built. However my engine was assembled in mid May. The pump that was on my car when I bought it was a long type Napa or some type of aftermarket unit. Being that the pump changeover from 065 to 811 occurred in April and my engine was assembled in mid May and car being built June 16, that left a pretty small date code window. I finally located a Tonawanda 811 pump dated 4/23/69.  Took me over a year to find an 811 pump dated prior to my May 16 engine build date. That pump is the 811 pump seen in the CRG water pump report.
« Last Edit: August 24, 2024, 01:24:22 PM by boomer632 »
06A X66 711 57 57 L78 M22 BU
Jonesy
  • 1969 Camaro z28
Re: Water pump
« Reply #4 on: August 28, 2024, 07:44:28 PM »
Your 69 L48 would have come with a 3927170 pump or 3953692 pump.
1969 Z28 Azure Turquoise
