Author Topic: L48 fuel line clips  (Read 4557 times)
BillGarrett
  • dwgarrett@yahoo.com
L48 fuel line clips
« on: June 08, 2024, 11:58:24 PM »
From my research, I think in part, due to Lloyds amazing restoration research and work, the Z28 302 fuel line clips have been covered but, for the L48 with Rochester carb duel line, frame rail clips, Im unsure about the colors.  Two of these clips can be seen underhood.  I've seen posts refering to green , black and even cad plating.  I've not seen any original underhood photos and, even if the're were, the lighting would need to be perfect to tell. Does anyone know the proper colors for these 2 underhood clips?
Re: L48 fuel line clips
« Reply #1 on: June 09, 2024, 07:38:16 AM »
Here is my LOS (04C) INDY pacers L48 Dual fuel line clip set as cleaned.
Hope you find this helpful. Best data I can offer.
BillGarrett
« Reply #2 on: June 09, 2024, 06:18:26 PM »
Thank you Jim.
BillGarrett
« Reply #3 on: June 09, 2024, 10:32:35 PM »
That is very helpful.  I can see the olive green on the clips.  once again, thanks!
« Reply #4 on: June 09, 2024, 11:14:34 PM »
One is also Zinc and One is Balck Ox. I can climb under the car and get you the layout order?
BillGarrett
« Reply #5 on: June 10, 2024, 01:47:06 AM »
Thanks Jim but, I think I have the order of it. My car is an L48 Pace car also.  I really wanted to cinfirm that olive green tone to those select clips and, you have shown that.  I've tried searches to reference the colors of the L48 fuel line clips but, have found none until now
Thank you..
« Reply #6 on: June 10, 2024, 01:49:49 AM »
Very Cool- Welcome.
I would think one could go to a Hobby shop and find an acceptable Green-Olive color from the Military Paint selections.
KevinW
« Reply #7 on: June 10, 2024, 01:20:03 PM »
Here is my attempt, found a Rustoleum self etching primer in dark green#249322
BillGarrett
« Reply #8 on: June 11, 2024, 09:17:59 PM »
Thanks Kevin.  I used that same product and got the same results.  I put a slight gloss on it when it dried.  Id post a pic if I could but, its close enough, i can live with it.
