Author Topic: Undercoating inside of the doors  (Read 7142 times)
john302
« on: May 07, 2024, 04:17:23 PM »
Was the undercoating inside of the doors applied after painting /priming ? There shouldnt be any type of overspray on it ?Thanks
CantRepeat
Re: Undercoating inside of the doors
« Reply #1 on: May 07, 2024, 04:27:00 PM »
I've never heard of undercoating put on the bottom of the doors but that's not to say it didn't happen.
Maybe you can glean some info from the assembly process report.
http://www.camaros.org/assemblyprocess.shtml
-Tim
« Reply #2 on: May 07, 2024, 05:15:57 PM »
Based my 1967 Build Model year 1968 Coupe (LOS)  the Interior cavity (LH) (RH) Door sound deadener was applied AFTER Body color was applied to the door including edge application and "overspray"
When Roger took this car apart he took photos of the door laying on the ground and you can see Clean 'undercoating' thru the door interior access holes.
D.W. should also have some details from his Red Car preservations.
JIM
« Reply #3 on: May 07, 2024, 06:01:07 PM »
Every car I've had, including customer cars and extra untouched spare doors have heavy undercoating after paint on the backsides of doorskins. Pics later as time allows.
« Reply #4 on: May 07, 2024, 06:40:47 PM »
« Reply #5 on: May 07, 2024, 11:31:22 PM »
I remember this old post: http://www.camaros.org/forum/index.php?topic=14385.msg126982#msg126982
That is helpful. I've never seen heavy body color on undercoating inside the door. If John said it did then I'll go by that. And by the doors I have for car I'm doing now, it makes sense. I suppose being asphalt based the paint did not adhere forever. Many times when I have to do hammer and dolly work on doors the undercoating(evidence) needs to be removed to do it properly.
CantRepeat
« Reply #6 on: May 08, 2024, 11:41:04 AM »
Sorry, for some reason I thought you were talking about the bottom side of the door.
I’ve learned something new.
-Tim
