Author Topic: Spare tire  (Read 7915 times)
Rustynut
Spare tire
« on: May 04, 2024, 05:14:59 AM »
I was able to find this information on an earlier thread, but I have no clue where to find the manual much less the part
Retainer, Jack Base (P/N 3929976, Group 8.820).
Thanks for the help
x66 714
Re: Spare tire
« Reply #1 on: May 04, 2024, 12:28:06 PM »
I'm not totally understanding your post. What year are you working with & is it LA or Norwood built? What pieces do you need to find?....Joe
Re: Spare tire
« Reply #2 on: May 04, 2024, 05:15:53 PM »
Badshifter
Re: Spare tire
« Reply #3 on: May 04, 2024, 07:46:26 PM »
I remember that 3929976 retainer being called out for convertibles only? The jack stores differently on a coupe, (left to right vs front to rear) and they use the base of the jack upside down to retain the spare.
1969 Z28 X77 09C
Rustynut
Re: Spare tire
« Reply #4 on: May 04, 2024, 09:18:42 PM »
1968 Norwood Built
I need to find a retainer for the spare tire
thanks!
Badshifter
Re: Spare tire
« Reply #5 on: May 04, 2024, 11:08:51 PM »
If you look at the standard (blackwall) tire & jack sheet (UPC 10, sheet A2), the coupe used #3949506 sticker, and the convertible used #3949513, and the spare wheel was installed with the outer face DOWN, and the jack base was installed with the top side DOWN. This sheet is for the standard equipment condition, which was blackwall tires.
If you look at the PW7/PW8 whitewall/redline/RWL tire & jack sheet (RPO PW7/PW8, sheet A1), the "model" block states "12300-467", which specifies the convertible body style, and that's what's shown in the illustration, using sticker #3949515. The illustration shows the spare wheel installed with the outer face (and the whitewall or redline or raised white letters) UP, using the added retainer #3929976, and the jack base was installed with the top side UP.
For the "SS", look at RPO L-48, non-illustrated parts list (sheet A2); under UPC 10, it says the spare wheel assembles the same as RPO L-35. If you go to RPO L-35, non-illustrated parts list (sheet A3), under UPC 10, it says the spare wheel assembles the same as RPO PW7, which specifies sticker #3949515.
Looks like that 3929976 retainer was only used if the car was delivered with red or whitewalls, or raised white letters (and possibly a convertible?).
Guessing that’s a tough find.
1969 Z28 X77 09C
GMAD_Van Nuys
Re: Spare tire
« Reply #6 on: May 05, 2024, 12:12:11 AM »
According to GM, the 3929976 retainer was for the 1968 & 1969 Camaro convertible:
http://www.gmpartswiki.com/getpage?pageid=76174
Rustynut
Re: Spare tire
« Reply #7 on: May 05, 2024, 01:14:40 AM »
Please forgive me for my ignorance. I have absolutely no idea where you guys find this information.
I have the hook, and wingnut, I just need a solid source for the retainer. Any help or explanation would be great!!!
David K
  • Dr. Longblock
Re: Spare tire
« Reply #8 on: May 05, 2024, 05:03:56 AM »
I have the STL file and can get one 3d printed if you need. Plastic is cheap, but I’m trying to source a metal printer. PM me if you want  to discuss further.
David K
  • Dr. Longblock
Re: Spare tire
« Reply #9 on: May 06, 2024, 04:48:01 AM »
Here’s a 3d plastic printed version. I’m trying to find a local printer for a metal part for authenticity visuals, and no work required to sand out the 3d lines.
Re: Spare tire
« Reply #10 on: May 06, 2024, 05:01:44 PM »
Which manual? The assembly manual?
Re: Spare tire
« Reply #11 on: May 06, 2024, 06:09:56 PM »
FYI acetone can be used to smooth out 3D prints to get rid of the ribs/ridges.
Badshifter
Re: Spare tire
« Reply #12 on: May 07, 2024, 01:19:12 AM »
David K that is a nice print. Did you scan an original? Or how did you arrive at that shape? Looks like a fairly simply stamping originally.
Rustynut is your car a convertible? Your profile says an SS 350 but makes no mention of a convertible. Unless the retainer you seek is not for your car? Just curious. Anyhow the “manual” is the AIM ( Assembly Instruction Manual) that Kurt S has made available to all.
http://www.camaros.org/forum/index.php?topic=9433.0
1969 Z28 X77 09C
Rustynut
Re: Spare tire
« Reply #13 on: May 12, 2024, 06:08:07 PM »
My car is not a convertible, however however I've read this is the correct retainer. If this isn't correct, what is?
Any help with this is greatly appreciated
rare396bronze
Re: Spare tire
« Reply #14 on: May 13, 2024, 12:21:08 AM »
Only used on 68-69 convertible not coupe! Coupe only uses nut and jack base like Badshifter picture 2nd one down on left side. Hope this helps.
