Author Topic: Muncie shift lever seal replacement  (Read 3265 times)
JST69Z28
« on: May 02, 2024, 12:38:47 PM »
Can you replace Muncie shift lever seals (in the side cover) in the car or does the transmission need to come out?  Mine drip oil.  I could not find any previous posts on this.  Thanks.
Kelley W King
Re: Muncie shift lever seal replacement
« Reply #1 on: May 02, 2024, 02:46:13 PM »
You can remove the side cover with the trans in the car and replace the seals. Not bad on a lift, but can be done with jackstands
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
GMAD_Van Nuys
« Reply #2 on: May 02, 2024, 03:10:34 PM »
There was a previous posting on CRG about replacing the side plate with the transmission still in the car:
http://www.camaros.org/forum/index.php?topic=15570.0
Kelley W King
« Reply #3 on: May 03, 2024, 11:18:54 AM »
It has been a long time since I did it, I may have rotated the trans when I did it.  It would be interesting to see a post after it is done. I did not see a reply by Mike on the other thread.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
