Author Topic: Wiper motor stamping  (Read 16331 times)
Re: Wiper motor stamping
« Reply #15 on: April 28, 2024, 02:18:40 AM »
I used the 1/4" tall stamps which were correct for the motor I did. If someone wants to borrow mine just give me postage. If I was going to lose sleep over an exact font match, a number stamp could be partially used and the incorrect portion hand painted. It's my job to do work that small.
.25 is a tad too small.
Use the .375 stamps if that's what yours is. The result can become larger after the stamp is loaded with paint as mine did. And any letter or number that is rounded on top or bottom is taller than one that is not rounded. An "O" is taller than an "E". Quite evident when someone hand letters, does not know this and their job is wrong. Any sign painter or artist might be happy to duplicate your font with precision.
« Reply #16 on: April 29, 2024, 02:14:08 AM »
That's a really good suggestion.
camaronut
« Reply #17 on: April 30, 2024, 04:42:18 PM »
I assume these date code stamps appeared in 69...........?
68L30
« Reply #18 on: May 01, 2024, 12:23:45 AM »
Here is what I’ve found, vintage United Delco. Font and technique is about spot on.
David K
  • Dr. Longblock
« Reply #19 on: May 01, 2024, 05:11:29 AM »
After falling down the rabbit hole…..
https://www.hprubberstamp.com/images/Pullman_Catalog.pdf
I’ll have to measure the one on my wiper motor….
calculations of .375=3/8”=Pullman 3
Calculations of .281=9/32”=Pullman 2 1/2
Looks to be Roman font
« Reply #20 on: May 01, 2024, 03:34:26 PM »
David, Here is my (1968) LOS stamping Different Font in my opinion.
Added clearer photo
« Reply #21 on: May 01, 2024, 04:31:38 PM »
NOR 03D - 45 68AB
LOS 12D - 32267AB (or possibly 22267AB)
EDIT:  Adding 2 more examples
67 BAL Chevelle 04C - 89 67FB
67 ??   - 158 66
« Last Edit: May 01, 2024, 05:07:13 PM by cook_dw »
David K
  • Dr. Longblock
« Reply #22 on: May 01, 2024, 04:52:40 PM »
Definitely different fonts and I'm thinking the stamp wasn't given much thought,  as long as it made it on the part.
David K
  • Dr. Longblock
« Reply #23 on: May 02, 2024, 03:24:53 AM »
The original one quit sometime in the late 80s, and I had a service replacement installed. I picked up this one from Pace Car Jeff last summer.
CantRepeat
« Reply #24 on: May 03, 2024, 10:03:07 AM »
Nice find. I looked through the brochure and the Roman font. The 6 and 7 don't appear to match up with Roman on the 67 model stampings.
I installed 3000 fonts on my computer and will try to get through most of them this weekend. Hopefully I can find a match and then someone to make a stamp with it.
-Tim
« Reply #25 on: May 03, 2024, 12:08:51 PM »
I've been in the business for decades. If I need certain artwork done for a job, I draw it myself. Then a printer or sign shop scans it and produces the product I need. Very easy process. And sign shops have programs that can manipulate any font or drawing.
David K
  • Dr. Longblock
« Reply #26 on: May 03, 2024, 05:33:20 PM »
Indy: I find it interesting there is no spacing on the stamp. Probably because it was stamped with something.
Can't repeat: Definitely a different font. It appears an8 band stamper with letter on the end are applicable some of the time.
CantRepeat
« Reply #27 on: May 03, 2024, 05:54:45 PM »
I went though the fonts and while none of them are an exact match these are the best of the lot.
« Last Edit: May 03, 2024, 07:11:41 PM by CantRepeat »
-Tim
bowtie68iho
« Reply #28 on: May 03, 2024, 06:16:06 PM »
Steve,
If I mail you a self-addessed stamped envelope, can you stamp "058 68" on an 8-1/2" x 11" piece of white printer paper and mail it back to me?  Then, I can get a rubber stamp made with that date code.  If interested, please PM a mailing address for my envelope.  Thanks!
Bernie
68 NOR SS/RS L48/M35 Convertible
Cordovan Maroon - Special Paint Exterior (black stripes)
Black Custom Interior
Silver Concours (Legends Class) at 2012 Camaro Nationals, Gold Concours at 2014 MCACN.
CantRepeat
« Reply #29 on: May 06, 2024, 11:14:46 PM »
I've order a stamp made with the Introit font and will post the results once I get it.
The rest of the restoration turned out ok. I think the screws holding the pump nozzles came out too shiny for the zinc but I was able to find the correct color nozzles. Most of the repops are bright white and don't match.
-Tim
