Author Topic: Excessive Oil usage on 302's  (Read 4059 times)
« on: March 16, 2024, 03:14:37 AM »
I've never seen this bulletin before. And note that it's not the normal all-yellow TSB. It does not have the word Dealer in the title either.
http://www.camaros.org/images/doc/TSB_69-T-4.jpg
rocco376
Re: Excessive Oil usage on 302's
« Reply #1 on: March 16, 2024, 08:02:20 PM »
Kurt, Have you ever heard of the problem?
boomer632
« Reply #2 on: March 16, 2024, 11:15:39 PM »
Interesting stuff. I'd like to see visual difference between the two.
06A X66 711 57 57 L78 M22 BU
« Reply #3 on: March 19, 2024, 02:12:22 AM »
No, never heard of the problem either.
Kelley W King
« Reply #4 on: March 19, 2024, 11:17:48 AM »
I remember the older smallblocks (pre PCV system) would sludge up the heads and #8 plug would foul out along with smoking and oil comsumption. Had nothing to do with the lifters.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #5 on: March 19, 2024, 11:52:41 AM »
I too would like to see the difference in the lifters. The '55 265's had oil problems but this ain't that.
Stingr69
« Reply #6 on: March 19, 2024, 02:05:30 PM »
The Chevy Power Manual has pictures of these lifters. The standard solid lifter was the "piddle valve" and it has a hole for oil feed in the machined down waist area (typical of the hydraulic and sold flat tappet lifters you see today). The "Edge Orifice" reduced oil feed solid lifters have the oil feed hole on the large diameter of the lifter body so it gets a lot less oil feed.
The Power Manual also shows the "Mushroom" solid lifter which has a larger foot that rides on the lobe and must be installed in the block from the bottom of the lifter bore.  The mushroom lifter can move the valve faster due to the larger foot at the cam. More agressive cam profiles are possible.
