Author Topic: Trans tunnel cutting at factory  (Read 16156 times)
DanZ10
« on: December 14, 2005, 03:06:47 PM »
John Hinckleys Assembly Process CRG Report didn't really address how the 4 speed shifter hole was installed on first gen camaros. Does anyone know what GM's practice was for cutting the shifter hole? Was it stamped, sawed, or burned with a torch?
RamAirDave
    • TheMuscleCarGuys.com
Re: Trans tunnel cutting at factory
« Reply #1 on: December 15, 2005, 07:42:13 AM »
The 67s, and I think the 68 s also, had a clean hole, while the 69s were torch cut.
dave
www.TheMuscleCarGuys.com
waynechipman
« Reply #2 on: December 19, 2005, 10:33:15 PM »
Don't know about 67 or 68 but 69 were definately torched in a semi oval
Classicgary
  • Guest
« Reply #3 on: December 20, 2005, 12:04:29 AM »
We've been here before. PLEASE put me down for stamped out. I've NEVER seen a floor/stick shift with a torched hole. I think Kurt or someone saved a picture I sent a couple of years ago of a '69 shifter hole. I've still got the dimentions written down somewere.
z10kl
« Reply #4 on: December 20, 2005, 02:35:55 AM »
I have three 69s that appear to be torched. And have seen other 69 bodys that appear that way.
waynechipman
« Reply #5 on: December 20, 2005, 03:05:49 PM »
The 69 three speed holes may have been stamped, but all four speeds were torched. They were still torching the four speed holes up to at least 1981 in the Camaros. If you have a stamped hole in yous it is most likely more of a square shape and a three speed hole. So I beg to differ as I have taken apart factory original Camaros with the torched holes. Don't really matter what anyone says, seeing is believing
wtexz10
« Reply #6 on: December 20, 2005, 09:55:12 PM »
Dan,
My 4speed Z10 is torched also.
Kris
69 Camaro Z10.. 72 GMC C1500
79 Mazda RX7.. 79 Trans Am WS6
06 Corvette Z06.. 10 BMW 650i
nuch_ss396
« Reply #7 on: December 26, 2005, 11:15:57 PM »
Would any members here have pictiral references for the 69 torched vs. cut shifter holes?  I for one would like to see how similar
they are from car to car.  Did the factory use a template for the torching operation?  Anyone know?
Steve A.
JKZ27
« Reply #8 on: December 31, 2005, 07:50:02 PM »
My 69 3-speed has a nice "stamped" clean cut rectangle hole with radiused corners. It uses a small bellows boot with a rectangle retainer surrounding a flat-stick muncie shifter.
John
John
68 RS Ash/Ivy Gold 327EFI M20
waynechipman
« Reply #9 on: December 31, 2005, 08:42:58 PM »
Yes Three speed is atamped 4 speed is torched, Except for a lot of Z/28s You see on Ebay
Tinkerr
« Reply #10 on: January 03, 2006, 06:55:45 AM »
I'm not that well versed on 3/4 speed holes.Why would the holes be different and how do 67/68 autos on the floor with linkage figure into this? I put a 4spd in place of the 3spd in my 67 and it fit,it did have a aftermarket shifter though.
mike396
« Reply #11 on: January 06, 2006, 02:42:36 AM »
I have a 69 convertible with a 4-speed and it has a torched hole. I am in the process of replacing the floors but I kept this section for refrence. I will most likely use my plumbing torch and a dull axe to duplicate the hole.
ibrockn
« Reply #12 on: February 16, 2006, 01:38:35 PM »
I have a 68 3-spd car that had the column shifter converted to a floor shifter. The location seems odd to me...closer to my right leg than I would expect. Are the 3-spd tunnel holes in the same location as the 4-spd holes?
