Author Topic: Factory Correct PCV Valve - 1968 Camaro Base Model Coupe 327/210 hp  (Read 4242 times)
gwp4
Hello First Gen Camaro Experts:
As a follow-up to an older post, I'm still trying to find the correct PCV Valve for my 1968 Camaro 327/210 hp standard model built on May 14, 1968 in Norwood Ohio.  The Legends judging manual states that in 1968 the PCV Valve is CV736C for all V-8 Camaros except the Z28 which received the CV746C.  When I checked the 1968 Camaro FAIM (UPC 6 C7 page 102) the part number is 6424251.  However, in the 1969 GM Parts Catalog Revised 7-1-69, the part number is 6423695.  I've attached copies of the FAIM and the parts catalog pages.  I'm guessing that CV746C is the correct PCV Valve, but I'm not sure why the GM part numbers are different.  Also, is there any variation/different color between CV736C for a May 68 Camaro and later 69/70 model Camaros?  Would a PCV CV736C with a date on the AC Delco box of 1972 be correct for Legends judging for a May 68 Camaro ?  Many thanks.  gwp4
David K
  • Dr. Longblock
Re: Factory Correct PCV Valve - 1968 Camaro Base Model Coupe 327/210 hp
« Reply #1 on: March 04, 2024, 04:29:03 AM »
GM typically combines other application models to 1 common part number. The parts manual is for service parts.
« Reply #2 on: March 05, 2024, 02:01:46 PM »
For your 68 the only correct PCV would be the spun valve design type CV736 IMO. Those are extremely difficult to find and in many cases if found, crazy prices.
bowtie68iho
« Reply #3 on: April 04, 2024, 12:36:37 PM »
There is an eBay vendor (i.e., Popsbowtie 67 thru 69 Camaro Parts) that knows a machine shop expert that custom makes the assembly line correct "spun" version of PCV valves with the AC type number stamped into the side (example: "AC SPARK PLUG TYPE CV-736 C") and the working valve inside.  Pricey, but where else can you get a correct original?  The link to his store so you can contact him for making one: https://www.ebay.com/str/popsbowtie67thru69camaroparts?_ipg=72.
Bernie
68 NOR SS/RS L48/M35 Convertible
Cordovan Maroon - Special Paint Exterior (black stripes)
Black Custom Interior
Silver Concours (Legends Class) at 2012 Camaro Nationals, Gold Concours at 2014 MCACN.
