Author Topic: Inner fender cup washers and bolt colors  (Read 10091 times)
69bigblock4speed
« on: February 27, 2024, 10:47:23 PM »
Do we know for a fact what color the fender cup washers were for a 69 Camaro, and how the color was made. Painted, Zinc, Phosphate???? Also for the bolts that hold them in place? Legend judges are saying the fender cup washers should be painted black with a Grey phophate bolt holding them in place. Is this correct?---Ughhh
R68GTO
Re: Inner fender cup washers and bolt colors
« Reply #1 on: February 27, 2024, 11:41:20 PM »
I believe that is correct.  When I stripped my low mile fender washers, you could see the pattern of black dip-painting....one spot had thick paint that virtually filled the edge of the recess on each one
1969 427 COPO Camaro Lemans Blue/Black, M22 4 speed, 15,500 original miles
169INDY
« Reply #2 on: February 28, 2024, 12:05:32 AM »
Get a Can of Semi gloss Rustoleum
RUST-OLEUMŽ
1-Quart Semi-Gloss Black Brush-On Protective Enamel
Mfg.# 7798502 Sku# 4523528
on a warm day, dip paint the washers and Hang to dry, they will come out smooth and with factory like coverage
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
« Reply #3 on: February 29, 2024, 04:01:27 AM »
RUST-OLEUMŽ
That's OK Jim if that paint matches but if sheen is off from his inner fenders it's going to stand out. Might want to find something that matches what you have.
69bigblock4speed
« Reply #4 on: February 29, 2024, 11:30:49 AM »
Talked to Brad from Legends. Very adiment that the washers are semi gloss black, and the bolts that hold them are Black zinc phosphate. As well as all the other bolts in the wheel well area, are the sam Black zinc phosphate. Basically he quoted word for word out of the Legends book, which I think is on page 53.
x66 714
« Reply #5 on: February 29, 2024, 11:59:41 AM »
If your car doesn't have style trim, the bolts that hold the fenders to the wheel wells will be phosphate. If you car has style trim, those fender/wheel well/lip molding bolts will be zinc. Don't forget to under coat the front wheel well, but only 1/2 way. (I lost points for over doing it) :) .....Joe
« Reply #6 on: February 29, 2024, 03:56:15 PM »
Brian Henderson sent me these pics this morning, from a 69.  Dip painted.
« Reply #7 on: February 29, 2024, 06:02:34 PM »
Good pic and since many other parts used the same paint one might want to have similar sheen or it will look out of place. I remember JohnZ stating they were dipped in semi-gloss lacquer primer.
« Reply #8 on: February 29, 2024, 09:05:46 PM »
 GM Reconditioning Black is what I used to get an OEM look.
I found that a first quick dip went on thin followed by a second longer emersion dip (after the first dried) gave it the factory look and better promoted the classic runs.
MO
« Reply #9 on: March 04, 2024, 04:30:59 AM »
Mike, is that still available?
« Reply #10 on: March 05, 2024, 12:06:44 AM »
 The new stuff is sold on Amazon under the name of GM Chassis Black Reconditioning Paint.
The GM can I bought from a Chevy dealer is about 20 years old but still sprays on nice and dries fast too.
It is not strong as todays 2K paint, but it looks more factory. I have seen different chassis black paints by other vendors but nothing as close to the GM paint results. I lost count of how many people asked me how I duplicated the factory sheen using the GM paint.
MO
« Reply #11 on: March 05, 2024, 04:21:20 AM »
Good to know. Thanks for that tip!!
