Author Topic: 69 rear leaf spring u-bolts  (Read 6420 times)
69bigblock4speed
« on: February 14, 2024, 11:58:54 AM »
On a 69 12 bolt rear-does anyone know what the length is for the 2 u-bolts are that go over the rear end tube and help bolt the leaf springs in place?
Also were they natural bare metal , black paint, or black or grey phosphate coming out of Norwood?
The bolts if my research is correct says they are 7/16 with fine threads?
Re: 69 rear leaf spring u-bolts
« Reply #1 on: February 15, 2024, 12:42:59 AM »
They were phosphate. Interesting question on length as my originals were shorter than later service replacements. I think I show some differences in my build thread.
69bigblock4speed
« Reply #2 on: February 15, 2024, 12:14:54 PM »
Yes I saw that picture of your u-bolts. You documentaion of that 68 restoration is amazing. I just can not find any info that states how long original u-bolts were.
You mentioned that the color was phosphate? I assume grey ?
With all the research you have done what color were the rear brake drums coming out Norwood on a 69 ? We all know that the rear were painted black, but did yther really paint the drums black too, or were they natural with Black overspray?
Pacecar
« Reply #3 on: February 15, 2024, 04:25:58 PM »
Drums were black
« Reply #4 on: February 16, 2024, 01:41:05 AM »
Gray phosphate and as Pacecar stated the drums are painted black. One way to get a view/feel for lenght is look at how much thread of u bolt is out from installed nut. It's not a whole lot. I have car stored away for winter or would try to get you a ball park length.
« Reply #5 on: February 16, 2024, 01:45:07 AM »
Look at post 1409 and note only three or so threads below U-bolt nut.
https://www.camaros.net/threads/time-for-another-68-z-28-to-be-restored.182584/page-71#post-1783182217
69bigblock4speed
« Reply #6 on: February 16, 2024, 04:45:30 PM »
Thank you
camaronut
« Reply #7 on: February 21, 2024, 12:53:06 AM »
Not to complicate things, but the Camaro Judging Manual says that the U bolts are black.......maybe a black phosphate?  See page 75 where it talks about the rear springs.  I looked this up because I almost took mine off to make them grey phosphate.
« Reply #8 on: February 21, 2024, 03:31:38 AM »
Possibly, but the book states black for just about anything that was phosphate. for technical "Black" is Manganese Phosphate. I used my originals and they were not Manganese Phosphate. Maybe others were or a different supplier.
69bigblock4speed
« Reply #9 on: February 21, 2024, 11:57:18 AM »
I wish there was a clear answer. I guess if you are going into Legends to be judged Black it is. So is Black- Manganese phosphate or was it Black zinc? Or are these two the same??
« Reply #10 on: February 21, 2024, 04:49:24 PM »
Use this:
https://www.palmettoenterprisesparkerizing.com/
Manganese Phosphate Charcoal (Black)
Also there are a few factors that affect finish appearance: Surface Prep, Time ins solution, Physical composition of material, Temp of solution, Concentration of solution.
With Both Zinc and Manga you can restore ALL manner of GM Factory Hardware without sourcing Expensive Re-seller or replacement hardware. The set up and care and handling of chemical is paramount to effectiveness and personal safety.  This is one of the BEST restoration "Hack" out there and in the 1980 was not known to many restorers. The quality of restorations has come a long way since 1982 Flat Black spray painted Hardware LoL
 Etc.
69bigblock4speed
« Reply #11 on: February 21, 2024, 05:25:42 PM »
Yes I Agree. We have come along way since the 80's. But what is better, zinc oxide in Black or the Manganese??
camaronut
« Reply #12 on: February 21, 2024, 05:44:54 PM »
Personally, I think we're getting a little too crazy on this stuff...LOL!
I mean - I get it ...........but geez!!!
« Reply #13 on: February 21, 2024, 05:55:02 PM »
Manganese (Parkerizing) Phosphate Charcoal (Black)
Zinc (Parkerizing) Phosphating Gray
For the Vendor above  I would use the Manganese, "if" you have some other source that is listing the solution as "zinc Oxide" it should render the similar dark charcoal or black results.  I used Don Dorfmans (ASL) Spark Nevada  "Black Oxide" solution back in the Day when I became aware (1985) of the correct blot preparations
« Reply #14 on: February 22, 2024, 03:48:28 AM »
https://www.camaros.net/threads/time-for-another-68-z-28-to-be-restored.182584/page-23#post-1677546
dang I'm losing it! I checked my pics and our original u bolts were dark and I did not re-do them or restore. I would call them manganese phosphate. Sorry for the confusion.
https://www.camaros.net/threads/time-for-another-68-z-28-to-be-restored.182584/page-22#post-1668891
