Author Topic: Prepping the 302 for heavy-duty service & 2x4 intake info  (Read 4537 times)
« on: February 11, 2024, 07:55:50 PM »
I found this GM writeup on prepping the 302 for H-D service. I also posted it in the Trans-Am forum since some of them don't venture into the other parts of the forum. ;)
http://www.camaros.org/pdf/Z28_HD_service.pdf
I also found some information on the 2x4 intake.
http://www.camaros.org/pdf/Z28_2x4.pdf
Both are in the library section of the site. http://www.camaros.org/library.shtml
« Last Edit: February 11, 2024, 09:26:31 PM by KurtS »
David K
  • Dr. Longblock
Re: Prepping the 302 for heavy-duty service
« Reply #1 on: February 11, 2024, 08:30:04 PM »
Roger that, thanks!
rocco376
« Reply #2 on: February 11, 2024, 08:36:05 PM »
Cool read.  Thank you, Kurt.
Stingr69
« Reply #3 on: February 11, 2024, 09:29:24 PM »
Just a thought - Might be good to post the "Green Sheets" car prep details, if you have them.
Re: Prepping the 302 for heavy-duty service & 2x4 intake info
« Reply #4 on: February 12, 2024, 02:31:46 AM »
Lots of things would be good to add. Gotta have scans to do that.
« Reply #5 on: February 12, 2024, 03:00:22 AM »
OK, why would it not be recommended to put new rocker arms in the exhaust position, only used ones?
« Reply #6 on: February 12, 2024, 04:31:33 AM »
Scans sent to Kurt.
JFW
« Reply #7 on: February 12, 2024, 05:40:44 AM »
Thanks Jim!
The Green Sheets are the updated version of the Super Sport Equipment manual. Both are now in the Library.
« Reply #8 on: February 12, 2024, 06:31:31 AM »
You Bet, Glad to Help.
« Reply #9 on: February 12, 2024, 03:42:52 PM »
In his book "The Unfair Advantage" Penske driver Mark Donohue mentioned having problems with burned rocker arms & balls during the '67 season. It became their practice to swap rockers and balls that had mated on an intake valve to an exhaust valve. Exhaust parts run much hotter than intakes; used parts resisted burning better than new ones.
« Reply #10 on: February 12, 2024, 07:16:58 PM »
That's a book I need to read, haven't done so yet. That makes sense I guess that you'd put one that is broken in first.
« Reply #11 on: February 14, 2024, 06:28:11 AM »
Read that book several years ago due to William’s suggestion and it’s a great read.
« Reply #12 on: February 15, 2024, 03:27:32 AM »
Great source
