Author Topic: What’s in the box?  (Read 6319 times)
David K
  • Dr. Longblock
What’s in the box?
« on: January 21, 2024, 12:41:07 AM »
Sometimes persistence pays off. And while my car isn’t a 69, I got the most elusive and important part.
rare396bronze
Re: What’s in the box?
« Reply #1 on: January 21, 2024, 02:57:16 AM »
Good find. Does the duct have a number on it is so what is the number on it. The duct is the only piece I have not found yet.
David K
  • Dr. Longblock
« Reply #2 on: January 21, 2024, 03:49:10 AM »
No number, just the C stamped on the front. Im going to get the broken tab issue resolved. Bronze....is yours a 68 or 69?
« Reply #3 on: January 21, 2024, 03:53:38 AM »
Hens teeth right there!
rare396bronze
« Reply #4 on: January 21, 2024, 05:11:42 AM »
1968
« Reply #5 on: January 21, 2024, 08:40:18 PM »
Yep, that be one hard one to find or replace. Congratulations....
David K
  • Dr. Longblock
« Reply #6 on: January 21, 2024, 09:57:58 PM »
Yea folks,we all know it. The good news is I have several appointments for 3D printing companies this week.
David K
  • Dr. Longblock
« Reply #7 on: February 03, 2024, 04:27:21 PM »
Scan done. I had to whittle a broken tab -that wasn’t from the piece for mock-up, and the scan shows it. The 3d image will eliminate it so it will be cosmetically correct. So far I like it. Definitely not my forte’ of expertise.
David K
  • Dr. Longblock
« Reply #8 on: February 05, 2024, 01:58:17 AM »
In the meantime while waiting for the 3d scan to be finished, I found a few pictures from here for the mount brackets. My car has a power top so I eyeballed it and it took a few Rolling Rocks, but it’s good and secure. I got 1/4” longer screws to get it sinched down. Mocked it up in the trunk and tis werkin. Whatever engineer designed this is a genius, but this bracket is not easy to make, even with aluminum.
I've uploaded a photo of an original for comparison.
ridesdirt
« Reply #9 on: February 08, 2024, 02:17:37 AM »
3D scan is very cool.
Sorry for the side track but I have a quick question about your last post.  That looks like a 67 rear defroster switch.  Do they mount on a bracket like that?  I assumed they just installed directly through the hole between the gauge cluster screws.  Which would make it vulnerable to a knee.
Now I am thinking I need to track down another part... or make my own, and I agree, it doesn't look like an easy one to make.
David K
  • Dr. Longblock
« Reply #10 on: February 08, 2024, 06:47:15 AM »
The bracket is only for power convertible top applications. Otherwise, the switch is mounted in the spot where the top switch normally goes. Do you need a bracket made?
David K
  • Dr. Longblock
« Reply #11 on: February 11, 2024, 05:45:07 AM »
Fixed the tab for full mock-up. Pulled the sill plates, ran the wires correctly in the channel, while simultaneously installing the rear speaker wire.
Drilled a big hole, installed the setup, smoke test completed, almost done.
