Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Garage Talk
67 z/28 rear end
« previous
next »
Print
Pages: [
1
Author
Topic: 67 z/28 rear end (Read 12301 times)
huggerSS69RS
Newbie
67 z/28 rear end
on:
December 11, 2023, 12:48:33 PM »
Hi,
Just wondering what the value of a 67 Z/28 rear end is? It's complete with drum brakes and brake lines, has correct codes, single traction bar bracket and posi centre.
Tweet
Logged
David K
Hero Member
Dr. Longblock
Re: 67 z/28 rear end
Reply #1 on:
December 11, 2023, 04:36:31 PM »
Are you referring to the housing with the correct stamped codes regardless of any gear that's inside?
Logged
CRG Member
Reply #2 on:
December 11, 2023, 07:57:07 PM »
Well it kind of depends on the date, ratio, and just what all is included. Do you have the correct dated ring/pinion and posi?
Logged
Bryon
/ 1968 Camaro SS 396 coupe - now old school 468 big block
MO
Hero Member
Reply #3 on:
December 12, 2023, 05:32:32 AM »
It really depends on what you have and provenance.
Logged
huggerSS69RS
Newbie
Reply #4 on:
December 12, 2023, 06:53:13 AM »
It's a complete rear end including drum brakes and brake lines that you can put into a car and run. It has QK code on axle tube (3.31 ratio) ending in G for Detroit gear and axle with E stamped below the date code for posi. Includes positraction plastic tag at filler bolt and leaf spring mounts. Centre housing has correct casting numbers and date codes for late 1966 and of course it has the bracket for traction bar on one side. I don't believe it's been apart as it still has posi inside and correct ratio gear set but I need to check date code on them. Just wish I had a 67 Z to put it into
Regards
Logged
x66 714
Hero Member
Reply #5 on:
December 12, 2023, 12:20:49 PM »
Although that rearend could've come out of a Z/28, it most likely came from a ss350. That was the standard gear ratio on that car. 3.73 was the standard gear ratio on a Z/28. Ratios went from 3.07 to 4.88.....Joe
Logged
CRG Member
Reply #6 on:
December 12, 2023, 05:38:52 PM »
I agree. Most likely from an SS 350.
Logged
Bryon
GMAD_Van Nuys
Member
Reply #7 on:
December 12, 2023, 07:50:33 PM »
CRG data on radius rods used on 1967 Camaros:
http://www.camaros.org/radiusrod.shtml
Logged
MO
Hero Member
Reply #8 on:
December 13, 2023, 07:28:20 AM »
Depending on the date code, it could also be from an L30/M20. Possible, but unlikely it came out of a Z-28. As for value, probably somewhere around 3k.
Logged
Print
Pages: [
1
« previous
next »
Garage Talk
67 z/28 rear end
