Author Topic: 68/69 Door Mirror Gasket w/CAMARO script  (Read 16182 times)
« on: December 07, 2023, 04:30:19 PM »
Amazing at times how we continue to learn things about our cars we didn't know prior. An excellent example brought to my attention at last year's 2022 MCACN involved noting a '69 Camaro door mirror gasket that had the word "camaro" molded in. My mind raced to our 68Z restoration as I thought I had carefully reviewed parts for details but unfortunately I do not remember even having the original door mirror gasket to review back then but was determined to find out more. First step was checking my good friends '68 07D and late '69 09D survivors if they had the camaro script door mirror gasket and they did. You do have to look for it as the mirror normally covers 50% to 70% of the CAMARO script and in some cases only part of the "C" can be observed due to both mirror length variation and other tolerance build up's and mounting processes. From reviews of survivors and talking to experts it appears the gasket used did have the "camaro" script.  I'm curious to know if this was common or the norm used during the 68/69 model run. Can anyone with paint survivors chime in on what your car has?
Picture of Skip's '68 Z/28 survivor 07D NOR rally green and of gasket from a NOR early spring 03D built 68 survivor still owned by original owner that Skip and I inspected several months ago.
Yes 68 03D NOR
Yes 68 07D NOR
Yes 69 09D (late) NOR
RikerZ28
Re: 68/69 Door Mirror Gasket w/CAMARO script
« Reply #1 on: December 07, 2023, 06:29:27 PM »
Here is my 69 Z/28 02D NOR Driver Side Mirror Gasket
1969 Z/28 02D X-33 / L72
169INDY
« Reply #2 on: December 08, 2023, 01:27:39 AM »
Yes 68 12D LOS
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
« Reply #3 on: December 09, 2023, 02:39:45 PM »
Yes 68 12D LOS
Yes 68 03D NOR
Yes 68 07D NOR
Yes 69 02D NOR
« Reply #4 on: December 13, 2023, 12:58:36 PM »
Friend sent me picture of his late 09B original paint with camaro script mirror gasket. I was hoping more members would be able to respond. I recently put a nice original I was able to find on our '68.
Gasket Part #3927398
Yes 68 12D LOS
Yes 68 03D NOR
Yes 68 07D NOR
Yes 69 02D NOR
Yes 69 09B (late) NOR
Danzo
« Reply #5 on: December 13, 2023, 11:22:00 PM »
Yes 05A Nor
copo
« Reply #6 on: December 14, 2023, 09:28:12 PM »
Yes 06A Nor
« Reply #7 on: December 15, 2023, 03:16:20 PM »
Yes 68 12D LOS
Yes 68 03D NOR
Yes 68 07D NOR
Yes 69 02D NOR
Yes 69 05A NOR
Yes 69 06A NOR
169INDY
« Reply #8 on: December 27, 2023, 03:52:53 PM »
Blurry enlarged 1968 Sample
68 Z28 M21 LOS
« Reply #9 on: December 28, 2023, 05:46:02 PM »
Thanks Jim, yours looks about the norm of what I've seen so far, that being mirror base hides approximately 50 to 66% of gaskets CAMARO script.
Again, I never reviewed, saw, or read anything concerning a 68/69 Camaro Door Mirror Gasket with the "CAMARO" script until seeing one on a '69 at the 2022 MCACN show. That led me to want to know more about this type gasket and its use. Checking some friends survivors I discovered it used on both '68 and '69 models and that led to wanting to find a nice one for our 68. Even though I kept just about everything original to our '68 that was not used I had no memory of keeping the original mirror gasket except deciding to use a new one for restoration. Just assumed I threw it away like the original door handle gaskets replaced with NOS gaskets. Well that all changed recently while searching my hardware bins for an original pair of screws and bingo, there was my original mirror gasket. And yes, it has the CAMARO script and quickly realized why we did not use as the bottom area of gasket has its lip broke off (see picture) which I've found in originals a lot when the mirror was placed rearward within the gasket.
Note in this picture how our factory mirror placement made an impression and how 80 to 85% of CAMARO script shown originally, but the bottom area of the gasket is broken as the base of the mirror during assembly would have been placed on top of the gaskets lower lip instead of being placed within the gaskets 360 degree lip.
The '68 NOR 03D Survivor cars gasket (shown again) we reviewed a few months ago had the same issue (one of the best I've noted with entire CAMARO script shown) with the lower part of gasket broke off. Owner placed mirror in gasket to mirror the original location of mirror to gasket and see how the mirror would have been placed on top of the gaskets lip. Broken lip similar to ours.
Badshifter
« Reply #10 on: December 28, 2023, 11:28:15 PM »
Yes.
69 09C Norwood (late)
1969 Z28 X77 09C
« Reply #11 on: December 29, 2023, 04:01:29 AM »
Yes.
Also received picture from Darrell of his '68 03D showing about 50% of the CAMARO script which I added.
Reference part #3927398 68/69 Door Mirror Plastic Gasket
Yes 68 12D LOS
Yes 68 01B NOR
Yes 68 03D NOR
Yes 68 03D NOR
Yes 68 07D NOR
Yes 69 02D NOR
Yes 69 05A NOR
Yes 69 06A NOR
Yes 69 09C (late) NOR
« Reply #12 on: January 07, 2024, 03:59:12 PM »
OK, you guys have been showing pictures of these gasket with Camaro on them. What am I missing that makes them unique from Nova or Chevelle?
« Reply #13 on: January 07, 2024, 07:48:20 PM »
I haven't heard that anyone has investigated other usages. They may have used the same part, or not.
« Reply #14 on: January 07, 2024, 09:05:22 PM »
I saw a Camaro and a Nova parked beside each other yesterday and the mirrors looked identical. Can't see what I am missing.
