Author Topic: My 1969 Camaro will not shut off  (Read 3544 times)
69z28rsbilly
« on: November 30, 2023, 12:53:03 PM »
What is causing my 69 camaro to keep running  after key is turned off ?
I have to pull coil wire to shut it off......
X33 72 72 RS
X33 71 71 RS
X33 10 10
Delco115
Re: My 1969 Camaro will not shut off
« Reply #1 on: November 30, 2023, 01:01:24 PM »
Not always but, sometimes......a little bit too high of an idle will cause this issue when turning off an engine. It doesn't take much of an adjustment to make a difference. As this is a very easy change to make, it may solve your problem.
rocco376
« Reply #2 on: November 30, 2023, 01:41:58 PM »
Is it running on like dieseling, or running like normal?  If running normally, it could be your ignition switch.  Dieseling could be a timing issue.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #3 on: November 30, 2023, 04:13:49 PM »
I agree - if it running like normal, then the ignition switch is not shutting of the power when you turn it off.
Richard
Richard Thomas
1969 RS
David K
  • Dr. Longblock
« Reply #4 on: November 30, 2023, 06:50:08 PM »
Sounds like the ignition switch assy is worn out and not disconnecting the electrical circuit internally.
« Reply #5 on: November 30, 2023, 10:29:17 PM »
Sounds like you got splainin' to do. What do you mean it keeps running?
Stingr69
« Reply #6 on: December 01, 2023, 05:53:09 PM »
Have you changed anything on the car recently?  Ignition box?  Some times you need a diode in the regulator circuit to prevent it from back-feeding.  I have one.
Badshifter
« Reply #7 on: December 02, 2023, 02:09:21 AM »
It’s not dieseling if pulling the coil wire shuts it off. That phenomenon requires no spark from the ignition.
1969 Z28 X77 09C
