Author Topic: 67 ss convertible  (Read 4934 times)
belair
67 ss convertible
« on: May 06, 2007, 06:28:20 AM »
hi all, im looking to buy this 67 convert camaro, they say orignal motor, but i have my doubts. cast# 3902406, cast date( im not sure where to find it) pad# L142277.  please let me know if you can decode it. thanks anthony.
Re: 67 ss convertible
« Reply #1 on: May 06, 2007, 09:32:46 AM »
belair -
The 3902406 block (L35 & L78 engines) was used in the Camaro in 1967.  The casting date on this block is located on the right lower side of the block near the freeze plug.  The L142277 could be the partial vin for a Los Angeles built car but should have a "7" before the L.  Does this "partial vin" match the last 7 digits of the vehicle's full vin?  Also, there should be an engine assembly code stamped here on the engine pad close to the partial vin.  Is the engine assembly code there?
belair
« Reply #2 on: May 06, 2007, 12:52:00 PM »
hi the numbers do match the vin, ill check the cast date & the pad to see if there is the # 7 & any assembly dates.
