Author Topic: Oil Fill Cap on my 250 Six Cylinder  (Read 3727 times)
Her68His69
« on: October 18, 2023, 08:19:57 PM »
What oil fill cap originally came on the car? It’s an 11A, 1968, build if that matters. I’ve seen both. And when and why did they change?
Her68His69
Re: Oil Fill Cap on my 250 Six Cylinder
« Reply #1 on: October 18, 2023, 08:22:21 PM »
Or this one
JerryGingras
« Reply #2 on: October 19, 2023, 12:06:32 AM »
My first 69 was a 230 (I posted about the head casting number in the 6 cylinder forum and noticed you did also about your car) - My aunt bought it new in 1969 - VIN#545064. I totalled the car in 1988 but still have alot of old docs, including protect-o-plate but never documented the trim tag.  Guess it was probably close to your November 68 car build though.  I remember it had the second style plain steel oil cap, not the tall first version.  Not a guarantee but doubt the oil cap had been changed by 1988, and I remember it was fairly worn meaning alot of the orange paint was either gone or it just had a plain steel finish but it definitely didn't have any marks or labels that I remember at the time I had it.  I have the whole engine still except I must have lost the valve cover over the years unfortunately.  Hope that helps.
Edit- I also think the tall "breather" vent cap would be used on applications without a PCV valve, which by 69 I think PCV would have been required for emissions (and then you would have a non-vented short plain oil cap) in most if not all applications.  I'm pretty sure mine had a PCV valve and I can see the PCV valve in your pic near the rear of your valve cover, so wouldn't think it would be the tall "breather cap" with vent holes in the bottom side (if that's what that tall one is), but should be the short one.
« Last Edit: October 19, 2023, 12:31:29 AM by JerryGingras »
Her68His69
« Reply #3 on: October 19, 2023, 02:26:58 AM »
Sorry, just to be clear, it's a 1968, built in November of 1967.
Her68His69
« Reply #4 on: October 19, 2023, 02:29:55 AM »
Thanks Jerry. I thought that the PCV valve would be the answer.
camaronut
« Reply #5 on: October 19, 2023, 11:05:26 AM »
Calling David K!!!    Calling David K!!!
Dave has an awesome 6 cyl car - he would know.
You can also look here: http://www.camaros.org/forum/index.php?board=16.0
Her68His69
« Reply #6 on: October 19, 2023, 04:46:13 PM »
Yes. I look for his posts all the time. I’m sure he will chime in.
David K
  • Dr. Longblock
« Reply #7 on: October 19, 2023, 07:03:56 PM »
Did somebody call for a Dr.? Dr. Longblock here. The correct cap is the 2nd one, and not the push in type typically found on the underpowered V8 vent tube. I do believe the cap was also painted orange with no labeling on it.
My car isn't 11E....what's is yours?
Her68His69
« Reply #8 on: October 19, 2023, 08:01:46 PM »
Actually it's my wife's car, mine is a 69, is an 11A, shipped November 8,1967. Both are Canadian sold cars, so we have some added documentation.
David K
  • Dr. Longblock
« Reply #9 on: October 20, 2023, 12:41:29 AM »
I'd like to see more pictures of the 6.
Her68His69
« Reply #10 on: October 21, 2023, 02:47:49 AM »
Any others?
stovebolt
  • 1968 L6 Sport Coupe
« Reply #11 on: October 21, 2023, 04:00:37 PM »
My 1968 04A. 230 cu. in.
