Author Topic: Correct Carb 69 396 325hp  (Read 23703 times)
Ejam
« on: May 05, 2007, 09:49:32 PM »
l have a 69 ss 396 325 hp that came with a quadrajet but the original carb is not with it. Does anyone know the correct carb number and a date? My guess is 7029200 but not sure of the date. The engine build date is T0416JG. Thank you Earl
Re: Correct Carb 69 396 325hp
« Reply #1 on: May 05, 2007, 10:24:44 PM »
Earl -
Good guess!  7029200 is the correct carburetor for the '69 Camaro 396-325 hp (L35) engine with the TH400 transmission.  The carburetor was installed at the car assembly plant, so it should be dated from about ten days to a month or two prior to the car's final assembly date.
Ejam
« Reply #2 on: May 06, 2007, 02:58:12 PM »
as far as date code on the carb. can you give a range that might have been good for my ar/motor? l'm not sure if Jan 1 was day one..... 1009? etc....
« Reply #3 on: May 07, 2007, 03:45:09 AM »
What's the build date of your car?
Ejam
« Reply #4 on: May 07, 2007, 08:05:40 PM »
04C
« Reply #5 on: May 07, 2007, 08:35:22 PM »
04C
Earl -
Any carburetor with a date code in the 02C - 04A range should be satisfactory.  Everyone agree?   :)
Ejam
« Reply #6 on: May 07, 2007, 08:44:13 PM »
ok so can you give me an example of the number/date that l might see on the carb?  they are 4 digit numbers l believe?
« Reply #7 on: May 07, 2007, 09:13:46 PM »
Earl -
A carburetor with a date code of 0489 to 0949 (2-17-69 to 4-4-69) should be satisfactory.  Everyone agree?
Ejam
« Reply #8 on: May 07, 2007, 09:29:09 PM »
thank you very much!
« Reply #9 on: May 15, 2007, 07:43:22 PM »
Unfortunately, there's some confusion in the various references on this carb.
The correct # 7029204 FF.
The date could even be a week closer (about 1019).
Ejam
« Reply #10 on: May 16, 2007, 02:01:20 AM »
Kurt I agree that is a possibility also thanks. whats the ff stand for?
« Reply #11 on: May 16, 2007, 02:35:30 AM »
Earl -
FF is the customer code, sometimes referred to as the broadcast code.
Ejam
« Reply #12 on: May 16, 2007, 02:49:29 AM »
I am seeing the 7029204 was used more for the 350 hp motor.
« Reply #13 on: May 16, 2007, 04:07:50 AM »
Possibility? Which, the date or the carb #? The carb # is the correct one. I believe the L34 auto used the same carb, but I can't confirm it, yet.
The 7029200 is not the correct carb.
Ejam
« Reply #14 on: May 16, 2007, 11:46:15 AM »
every book l've been reading is showing the 7049200 as the carb used for the 69 L34 325 hp. what publication are you getting the 7049204 from? thanks
