Author Topic: Another PCV Valve Setup Question  (Read 15166 times)
FLA-67RS
« on: October 02, 2023, 02:59:06 PM »
I have a LOS built 67 RS with the base 327 2BBL engine. The car was originally sold in December of 1966 by Merle Stone Chevrolet in Exeter, CA, so I believe it had the K19/K24 components, which were removed at some point by previous owner(s). The current set up is shown in the picture and has the PCV valve screwed into the oil fill tube and the hose going to the base of the carburetor. The oil filler cap is vented. What are the thoughts on if this is adequately venting the crankcase? Is air being mostly drawn in through the vented oil filler cap and going directly to the carburetor?
1967 RS - LOS 12A Grenada Gold with Gold Interior
Rare Options - AS1 Shoulder Harness, AS2 Headrests, A67 Folding Rear Seat, C50 Rear Defogger, C60 Air Conditioning
Kelley W King
Re: Another PCV Valve Setup Question
« Reply #1 on: October 02, 2023, 03:15:04 PM »
that is not the correct oil fill cap. Should be non venting if that is the correct PCV setup for your car.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
FLA-67RS
« Reply #2 on: October 02, 2023, 04:23:08 PM »
Agreed. However, there is no other vent for outside air to enter the crankcase which is why I believe it is setup this way.
Kelley W King
« Reply #3 on: October 02, 2023, 05:49:42 PM »
a 67 engine has a hole by the distributer hole which has a tube leading to the air cleaner base to draw air from inside the air cleaner. 68 and later blocks do not have this hole. The fresh air from the air cleaner goes in the vale cover and the PCV is in the opposite valve cleaner.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
FLA-67RS
« Reply #4 on: October 02, 2023, 06:09:13 PM »
I know what the correct setup should be for the PCV valve, my real question is "based on my current setup, is it adequately ventilating the crankcase". Thanks for the replies.
GMAD_Van Nuys
« Reply #5 on: October 02, 2023, 09:31:43 PM »
Other owners report having the PCV valve attached to the oil filler tube:
https://www.camaros.net/threads/67-327-pcv-valve-setup.38103/
You can also purchase the tube with the PCV fitting from a number of sources:
https://www.classicindustries.com/product/all-years/chevrolet/camaro/parts/PR1251.html?gclsrc=ds&gclsrc=ds
You might want to replace the breather with a cap.
« Last Edit: October 02, 2023, 11:01:19 PM by GMAD_Van Nuys »
FLA-67RS
« Reply #6 on: October 02, 2023, 11:50:41 PM »
Thanks for all the responses, they are always helpful.
David K
  • Dr. Longblock
« Reply #7 on: October 11, 2023, 03:08:32 AM »
Was the car a manual or automatic?
David K
  • Dr. Longblock
« Reply #8 on: October 11, 2023, 03:11:09 AM »
From the 67 AIM. I think you are fine.
FLA-67RS
« Reply #9 on: October 11, 2023, 11:35:44 AM »
David,
Thanks for the reply. The car originally came with the Powerglide transmission which changed out to a TH350 by a previous owner.
MO
« Reply #10 on: October 12, 2023, 04:46:39 AM »
It probably vents enough, but I wonder if the PCV functions as intended being located so close to the vented cap?
