Author Topic: Can I get some clarification please.  (Read 7574 times)
68L30
Re: Can I get some clarification please.
« Reply #15 on: September 17, 2023, 02:10:02 AM »
Can I get a link to the thread?
Look in the “Restoration” section in this forum. I brought it to the top…
http://www.camaros.org/forum/index.php?topic=1726.0
David K
  • Dr. Longblock
« Reply #16 on: September 17, 2023, 02:45:58 AM »
Yea Kurt, sometimes we can’t see the forest through the trees. I just epic failed on that.
68L30
« Reply #17 on: September 17, 2023, 05:58:55 PM »
TSB
68L30
« Reply #18 on: September 17, 2023, 05:59:26 PM »
Pg 2
David K
  • Dr. Longblock
« Reply #19 on: September 18, 2023, 01:02:40 AM »
Interestingly enough, back in 1990 or so, I installed one with adhesive backing. When I wrecked the car, it went away. Now I don’t even see anyone selling that style…just the one pins.
68L30
« Reply #20 on: September 18, 2023, 02:09:29 AM »
Honestly, your car is way too early to have these factory installed. Dealer TSB installed, most likely. Even then it’s got to be pretty rare. Did they install the side baffles rubbers with screws?
David K
  • Dr. Longblock
« Reply #21 on: September 18, 2023, 05:50:11 AM »
L30—To have the pins holding the seal?
No side baffles-Tis a convertible.
68L30
« Reply #22 on: September 18, 2023, 08:51:52 AM »
Way too early to have everything….unless it was installed by the service department.
Steve.
« Reply #23 on: September 18, 2023, 11:31:41 AM »
It’s held on with clips. The later core supports are pierced with holes across the top to push the clips into. Non-AC cars have dimples where the holes are. Non of the repro seals have aprovision for the clips/ pegs. Tough to find…
Just to clarify I believe "Dimples in core supports" started late '68 model run.
« Reply #24 on: September 18, 2023, 01:01:35 PM »
Steve, curious because your 68 is that late of a build, does the core support have the holes for the 69 style condenser?
« Reply #25 on: September 18, 2023, 05:18:02 PM »
All the relevant 67-69 TSB's are on site. 68: http://www.camaros.org/library.shtml#doc68
I question that it was a late release. The AIM show a 11/3/67 drawing date and no revisions.
Time to query owners of 68's with AC.
68L30
« Reply #26 on: September 18, 2023, 08:53:26 PM »
The TSB states 6-19-68. If it was done prior to this date there would be NO reason for the TSB. That’s very clear. The service addition is very different from the factory mount in how things are attached. I cant’t tell you why the AIM shows one thing, but dated at the tail end of 67, you can bet it didnt happen till later in the model year. Survivor Cars I’ve documented as late as April had no provisions for any of the seals and baffles. Late June / July do. Surprised nobody has commented on the other link I posted in our Restoration section. We beat this to death back in 2007….
68L30
« Reply #27 on: September 18, 2023, 09:19:00 PM »
It has a “68 production run” core support. A/C lines go under the support. It’s never been out of the car.
« Reply #28 on: September 19, 2023, 12:21:28 PM »
I am not questioning the originality but was wondering if there was bleed over into 68 being that late into production.  Thanks for the clarification.
68L30
« Reply #29 on: September 19, 2023, 04:31:06 PM »
Completely understood, I just wanted to be clear that without a doubt, this O7E car came as stated. Pretty close to A final call in 68.
