Author Topic: Rear end gear ratio  (Read 3157 times)
Rustynut
Rear end gear ratio
« on: September 07, 2023, 01:40:12 AM »
Which Rear end gear ratio was available on 1968 Camaro SS 350  with borg warner 3 speed and 12 bolt?
Please and thanks
Rustynut
Re: Rear end gear ratio
« Reply #1 on: September 07, 2023, 06:58:10 AM »
Any chance 4:10 gears were an option?
68 Ragtop
« Reply #2 on: September 07, 2023, 01:09:31 PM »
I don't see 4:10 available as an option on the powertrain chart.
3.31 std, 3.07 econ, 3.55 perf, and 3.73 spec.
« Reply #3 on: September 07, 2023, 05:55:51 PM »
I have never seen one with a 3 speed and 4.10 gears. Possible with M20.
Do you have one?  How does the axle assembly date compare with the car assembly date?  Have an docs?
Rustynut
« Reply #4 on: September 07, 2023, 06:27:38 PM »
Yes I do have one, but haven't checked any dates yet. I guess that would be a logical next step, thanks
« Reply #5 on: September 07, 2023, 07:50:33 PM »
Please check the front edge of the passenger side axle tube for the assembly date and the center section for the casting date.
http://www.camaros.org/drivetrain.shtml#axle
Also if possible post details of the engine and transmission.
You can send me a direct pm if you want.
« Last Edit: September 07, 2023, 08:56:27 PM by bcmiller »
« Reply #6 on: November 03, 2023, 02:30:13 AM »
