Author Topic: Tachometer Z-28 Required  (Read 10038 times)
RikerZ28
Re: Tachometer Z-28 Required
« Reply #15 on: August 15, 2023, 01:48:59 PM »
Jon, I went out and looked at my 02D X33 and what you think is the oil pressure oil line hole is the speedometer cable clamp mount. From what I see in your long shot there is a dimple in the firewall which is parallel to the bottom windshield wiper motor mounting screw. That is where on my car the oil line grommet is.
1969 Z/28 02D X-33 / L72
RikerZ28
« Reply #16 on: August 15, 2023, 01:54:49 PM »
camaronut, I think it is that way with the two hole as the clamp is made not to rotate, To keep the cable straight coming out of the 4 speed grommet. Thanks, Bob
x66 714
« Reply #17 on: August 15, 2023, 01:59:52 PM »
This is a picture I took of my firewall. I had several holes to fill but the oil line hole is the original....Joe
RikerZ28
« Reply #18 on: August 15, 2023, 02:12:45 PM »
For 4 Speed cable clamp, check G80 A2 and M20 A9
RikerZ28
« Reply #19 on: August 15, 2023, 02:18:25 PM »
Hey Joe, thanks for the picture! Your car is an automatic but you can see from your picture that there is a dimple in the firewall where the clamp would be mounted. Thanks, Bob
Iowa Jon
« Reply #20 on: August 15, 2023, 02:29:03 PM »
Thank You Bob! I now know were the speedometer cable goes.:)  And I am back to no gauges and no Tach.  When I bought this car it was in boxes.  CRG site is great.  Helping me a lot.  Jon
RikerZ28
« Reply #21 on: August 15, 2023, 02:51:55 PM »
Jon, I'm not the expert, but glad to help.
Still looking for an answer of did U17 use a 1/2 hole under the fuse block like U16 or not?
Thanks, Bob
GMAD_Van Nuys
« Reply #22 on: August 15, 2023, 07:36:52 PM »
You can buy a reproduction grommet for the oil pressure line from the vendor below:
https://www.heartbeatcitycamaro.com/20453/67-68-69-Camaro-Console-Gauge-Oil-Line-Firewall-Grommet-GM%23-3906193/
x66 714
« Reply #23 on: August 15, 2023, 09:14:42 PM »
Thanks, Bob
U17 didn't have a hole under the fuse box. The reason being is the wire for the tach was part of the main harnessing. Only U16 had that...Joe
RikerZ28
« Reply #24 on: August 15, 2023, 10:32:33 PM »
Hi Joe, Thanks for clearing up my confusion! Sometimes these video are so sure of the facts or only half truths. That's why CRG is the best!
Thanks Again!
Bob
