Author Topic: 1967 Camaro convertible RSSS with extra hole on dash  (Read 3754 times)
Rsweet68
« on: August 11, 2023, 01:11:56 AM »
Hello,
I’m looking for some help with my 1967 RSSS convertible with the 350 and Powerglide transmission. There is an extra hole with the ignition switch and lighter on my dash. It has a raised lip as though it came from the factory this way. I have attached a picture and circled the hole in question.
Russ Seeet
David K
  • Dr. Longblock
Re: 1967 Camaro convertible RSSS with extra hole on dash
« Reply #1 on: August 11, 2023, 04:28:45 AM »
Tis not factory. Quite possible a dealer item but most likely a manual choke…however we all know not everything.
MO
« Reply #2 on: August 11, 2023, 05:15:56 AM »
Ditto on the manual choke. I had a 67 coupe with one in the same location.
philip
  • hello from FRANCE
« Reply #3 on: August 11, 2023, 10:40:39 AM »
Does you’re car came from europe ?
If yes, they installed extra headlights vehind the grille and an interruptor at this place.
Look here...
http://www.camaros.org/forum/index.php?topic=20700.0
convertible 1967.12467
RPO: A02-A31-A67-B37-B93-C06-D55-F41-G80-J50-J52-K02-L30 -M20-N33-N40-N61-U17-U18-U25-26-27-28-29-V31-V32 Z21-Z22-Z87
« Reply #4 on: August 11, 2023, 11:41:21 AM »
Unless you planned to fill the hole I would suggest using the hole like Yenko did and mount a tach in that location.  But that's just me.
MO
« Reply #5 on: August 12, 2023, 05:51:09 AM »
Look here...
Yeah, a good suggestion. Possible location for added fog or driving lights as well.
