Author Topic: 1967 Camaro 327/275 HP with 2 speed power glide correct starter number  (Read 5169 times)
weave470
I am looking for the correct starter number for my May 9, 1967 Camaro. I have a couple of books that I have been reviewing. The Factory Assembly Instruction Manual shows UPC 6 1107496 with a revision of 5/31/66 to 1107320. With another revision 12/22/66 back to 1107496. The Service Manual shows 1107320. Legends Judging Manual shows 1107496 for small block cars in 1967.
TIA
Ken
David K
  • Dr. Longblock
The service manual is a universal post factory replacement number.  What’s your build date?
eBay item number:166219031723
weave470
The engine stamp is T0509MM.  May 9, 1967.  Cowl tag 05C so third week of May.
David K
  • Dr. Longblock
Can you post pictures of the differences from the AIMs?
weave470
Here is picture of the UPC.
weave470
Re: 1967 Camaro 327/275 HP with 2 speed power glide correct starter number
« Reply #7 on: August 03, 2023, 03:19:51 PM »
Update
So I picked up a 1107496 Delco Remy starter the other day.  Upon inspection of the starter the bolt pattern does not line up with my engine like the 1107320 starter.
« Reply #8 on: August 03, 2023, 04:14:01 PM »
Swap the noses and you are good to go.  It was probably rebuilt at some point and the nose was installed.  Pretty common for reman companies.
weave470
« Reply #9 on: September 02, 2023, 11:40:14 PM »
In regards to the starter nose of the 1107496, were they cast iron or aluminum?
TIA
GMAD_Van Nuys
« Reply #10 on: September 05, 2023, 08:08:48 PM »
I found this information about the material used on the starter cone on a Corvette website:
https://www.corvetteforum.com/forums/c1-and-c2-corvettes/3802893-starter-nose-cone-identification.html
GMAD_Van Nuys
« Reply #11 on: September 06, 2023, 02:31:59 PM »
There is a starter with part number 1107496 for sale on eBay which appears to be original:
https://www.ebay.com/itm/403188733785
