Author Topic: Trim Tag Research - Real or Repop?  (Read 5273 times)
Jaiderz
« on: June 21, 2023, 02:23:45 AM »
Trim tag from 68 Z/28
Re: Trim Tag Research - Real or Repop?
« Reply #1 on: June 21, 2023, 03:27:04 AM »
It should read: Trim tag from 68 Coupe.
Nothing suggests the RPO('s) installed on this model
« Reply #2 on: June 21, 2023, 12:25:57 PM »
Can you send more info as to why you believe it is a Z?   Tags real but as Jim stated nothing there other than build date, body sequence, color and interior.  Tag looks to have been removed or at the very least attempted to be.
« Reply #3 on: June 21, 2023, 01:12:54 PM »
The VIN is 124378N422879 and it was on ebay back in August of 2015 by seller horseracin4fun and at that time it had a restamped engine.
Jaiderz
« Reply #4 on: June 21, 2023, 06:05:43 PM »
Sorry, I should have clarified - the tag is actually on a Z.  I was checking on expert opinions based on the tag situation it was real or if anything was concerning about it.
Jaiderz
« Reply #5 on: June 21, 2023, 06:06:42 PM »
bertfam - how were you able to track down the vin?
« Reply #6 on: June 21, 2023, 06:15:52 PM »
Quote
From the body number. And how do you know it's a Z? What documentation do you have?
Jaiderz
« Reply #7 on: June 21, 2023, 06:40:35 PM »
I have no documentation - I guess that is what I'm trying to determine if, in fact, it is a true Z/28.
David K
  • Dr. Longblock
« Reply #8 on: June 21, 2023, 06:51:01 PM »
Unfortunately the 68 cars were bare minimum on information for options.  Interior color and exterior color. Nothing else.
You could upload the rear axle, transmission and engine information to start. However as Ed states, the engine is a restamp.
« Reply #9 on: June 21, 2023, 06:51:34 PM »
You'll need to post good, high resolution pictures (or email them to me) of the following:
1. VIN
2. Engine pad stamp located on the front passenger side of the block
3. Transmission suffix / date code located on the driver side of the transmission toward the front
4. Rear axle suffix / date code stamped on the front of the passenger side axle tube
5. Rear axle date code cast into the center section
Without documentation it's impossible to determine a 68 Z28. You can do a "best guess" by the above, but you can never be absolutely positive.
Jaiderz
« Reply #10 on: June 21, 2023, 07:02:19 PM »
Thanks, Ed!  I'll see what I can put together.
