Author Topic: 1969 trunk divider 2.0  (Read 13627 times)
Danzo
« on: June 17, 2023, 11:41:55 PM »
I just could not accept the current ones offered. Made my own.
Doc
« Last Edit: June 18, 2023, 12:22:32 AM by Danzo »
Chuck-68-Cam
  • It is what it is
Re: 1969 trunk divider 2.0
« Reply #1 on: June 18, 2023, 12:13:39 AM »
Nice!
Chuck
68 Camaro SST 350/TH400
« Reply #2 on: June 18, 2023, 03:18:04 AM »
Yes, Great job Doc!
R68GTO
« Reply #3 on: June 18, 2023, 10:42:49 AM »
Looks great!  I always appreciate the work people go through to make things right.  It might be the photo angle....are your relief cuts for the wheel housing slits or V's?  Should be V's.
Danzo
« Reply #4 on: June 18, 2023, 12:40:22 PM »
The 'Vs" just have to be trimmed out prior to installation.
Doc
Edgemontvillage
« Reply #5 on: June 20, 2023, 08:34:32 PM »
Doc, what paper / fiber board material did you use and where can it be sourced?
« Reply #6 on: June 21, 2023, 12:28:46 PM »
That's a potential money maker if you wanted it to be.. depending time and cost.  Looks good.
Danzo
« Reply #7 on: June 21, 2023, 11:52:38 PM »
Lloyd, it is fiber/panel board a friend of mine who is a cabinet maker found.
luv2sixty9
« Reply #8 on: June 22, 2023, 01:57:04 PM »
Nice Job!
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
Edgemontvillage
« Reply #9 on: June 26, 2023, 04:53:36 PM »
Doc, it would help those of us who might consider a similar approach to replacing the original divider to learn more details about the material used (thickness, product name, specs, sourcing etc) if you wouldn't mind asking your cabinet maker friend?
Danzo
« Reply #10 on: July 04, 2023, 03:48:35 PM »
Talked to my friend, not much help. He purchases it from a salesman who told him it is made overseas. When the order is placed it is a 50 sheet minimum and comes as a 4x8 sheet (natural color). The thickness is .070", has no product name, and is very similar (material and thickness) to another friends resto house bought divider. He has always referred to it as panel board. I was given a 2x5 piece and I did the rest. The limited number of these dividers I have seen in the wild plus pictures show an original to be 2 pieces "glued" together. Here is a photo showing an original one with the thickness. 2 of the one I made "glued" together would be dead on.
Doc
David K
  • Dr. Longblock
« Reply #11 on: July 06, 2023, 03:13:45 AM »
If your friend isn’t much help, you need a new friend.
70z28lt1
« Reply #12 on: July 06, 2023, 12:54:01 PM »
I've done a few of the dividers for 1970 Camaros and ran into the same material supply issue.  The 70 divider is about 0.093 inch thick so I laminate a 0.060 and 0.031 sheet together.  I found the material here:
https://www.dickblick.com/products/utrecht-chipboard/?Size=29%22%20x%2046%22&
cutting it:
https://youtu.be/XY2jNbW_nU4
« Last Edit: July 06, 2023, 01:14:07 PM by 70z28lt1 »
Edgemontvillage
« Reply #13 on: July 06, 2023, 03:33:56 PM »
Nice work and good intel - thank you. Is that your Mastercut plotter in the video?
70z28lt1
« Reply #14 on: July 06, 2023, 03:56:00 PM »
Yes, it is.  Well, it is at where I work.  We use it for prototypes for customer parts.  Very handy, but you have to create a CAD file first.  It is a CNC xacto knife.  The table has a large vacuum pump that holds the sheet in place.
