Author Topic: Hole in trunk pan for 1969 camaro for fuel sending unit  (Read 3853 times)
hdptsr
« on: June 09, 2023, 11:45:19 PM »
Hello,
I had to replace my trunk pan, and am now installing the fuel tank and sender.  I realized I did not take note of where the sending unit comes through the trunk pan.  Does anyone have a picture and measurements where this hole for the tan wire should be drilled.  What is the whole size?  Also where does the ground wire attach?  Thanks for your help.
Re: Hole in trunk pan for 1969 camaro for fuel sending unit
« Reply #1 on: June 09, 2023, 11:51:59 PM »
3/4" Diameter
hdptsr
« Reply #2 on: June 09, 2023, 11:59:27 PM »
Do you have any pictures or measurements where to drill the hole?
« Reply #3 on: June 10, 2023, 01:58:32 AM »
You can scale it appx & double check your sender grommet before final drilling.
1969 LOS Vert.
Others can double check
Badshifter
« Reply #4 on: June 10, 2023, 02:04:13 PM »
The ground wire attaches here, on the doubler that the tank straps attach to.
1969 Z28 X77 09C
Edgemontvillage
« Reply #5 on: June 16, 2023, 02:55:52 AM »
Alternate View - Location of Sending Unit Ground
« Last Edit: June 16, 2023, 03:33:36 AM by Edgemontvillage »
« Reply #6 on: June 16, 2023, 05:03:24 AM »
Lloyd do you have a "After" photo?
It is a 'loaded question, I want to discuss the "Electrical Terminal" used Originally and on GM service parts and repop / aftermarkets.
Edgemontvillage
« Reply #7 on: June 16, 2023, 03:29:08 PM »
Jim, I'll assume this is what you meant. The original, factory installed fuel sending unit ground wire terminal has a squared off end and an integrated washer in the center which is unseen when the grounding screw is attached (per the photo in Reply #5). The GM service replacement (non-reproduction) ground wire terminal is oval and does not have an integrated washer. For Legends judging the GM service replacement sending unit is accepted without a points deduction providing a star washer is added and is visible. In the photo below I have not added the star washer.
Original fuel sending unit ground wire terminal with integrated washer
GM Service Replacement sending unit ground wire and terminal (star washer not added)
« Reply #8 on: June 16, 2023, 08:44:48 PM »
Attempting to Source
