Author Topic: Engine weight comparison  (Read 7654 times)
« on: June 06, 2023, 02:57:25 PM »
I ran across this comparison of engine weights - complete engines less bellhousing, flywheel, and clutch. Think DZ vs L78 vs L89 vs ZL1. This is comparison of nominal weights - a L78 vs a LS6 vs a L88 are going to have some minimal weight differences.
All variances (in parentheses) are from the iron small block.
Small block, cast iron   -   520 pounds
Small block, iron w al head  - 480   (-40)
Small block, al head & block - 389  (-131)
Big block, cast iron   -       754  (+234)
Big block, iron w al head  - 660 (+140)
Big block, al head & block - 501 (-19)
Re: Engine weight comparison
« Reply #1 on: June 06, 2023, 04:39:11 PM »
It would be nice to know what the 6 cylinder weighs.
« Reply #2 on: June 06, 2023, 07:04:22 PM »
Yes, it would. But I was really happy to find this data, I've never seen it before.
GMAD_Van Nuys
« Reply #3 on: June 06, 2023, 07:40:38 PM »
According to the website below, the Chevrolet 6 cylinder engine weighs 440 lbs:
https://suicideslabs.com/dw/library/txt/engfyi.htm
sixt9x33rs
« Reply #4 on: June 27, 2023, 02:24:34 AM »
Thanks for posting Kurt
David K
  • Dr. Longblock
« Reply #5 on: June 27, 2023, 05:45:52 AM »
6 cylinder, better handling than a V8. Weight is centered. Lighter. So said R&T back in 67/8.
67conv6cyl
« Reply #6 on: June 30, 2023, 10:16:19 PM »
I have both 67 6 cylinder convertible and 67 327 V8 convertible…..6 cylinder car most definitely handles better (it actually is a surprisingly significant difference) both cars have same size front sway bar.
« Reply #7 on: July 04, 2023, 04:13:11 AM »
Some of the early 67 L6 cars didn't come with sway bars!
« Reply #8 on: July 04, 2023, 11:03:46 AM »
Thanks Kurt. Personally I would like to see the numbers for
L34/L35 - cast iron block, heads, intake manifold
L78 - cast iron block and heads, aluminum intake manifold
L89 - cast iron block, aluminum heads and intake manifold
ZL1 - aluminum block, heads and intake manifold
67conv6cyl
« Reply #9 on: July 04, 2023, 01:15:34 PM »
I thought all Convertibles had sway bars regardless of engine or build date? , my 6cyl convertible is April build date and it does have factory sway bar. My 67 327 is February build with exact same sway bar.
David K
  • Dr. Longblock
« Reply #10 on: July 04, 2023, 03:16:02 PM »
Back in the 90s, my Camaro club had an annual show. One contest besides the tricycle races was the engine block pull. We had a piece of plywood on the bottom of a 6 and it was a timed event. Definitely a hoot watching kids drag that thing.
DuWayne Ladner
« Reply #11 on: July 04, 2023, 04:13:24 PM »
Would like to know the actual weight of complete cars of a L78, vs. L78/L89. Just curious!
