Author Topic: Caveat Emptor...tags  (Read 3987 times)
« on: June 01, 2023, 02:17:02 AM »
https://bringatrailer.com/listing/1969-chevrolet-camaro-z-28-136/
124379L507447
L507447 was final assembled on or about November 7, 1968. Car has an 11B body tag, second week November 1968. Data on the tag does not compare with other L507xxx VINs. The VIN tag is attached with common pop rivets due to dash top replacement.
One or both tags are not original to the car; hidden VINs may not match.
boomer632
Re: Caveat Emptor...tags
« Reply #1 on: June 01, 2023, 12:07:29 PM »
Good catch. The one pic of the firewall, TT is missing...
06A X66 711 57 57 L78 M22 BU
MO
« Reply #2 on: June 02, 2023, 04:15:59 AM »
Wow!! The vin tag rivets are only part of the problem.
Turboragtop
« Reply #3 on: June 15, 2023, 03:39:45 PM »
Where is the hidden VIN located?
MO
« Reply #4 on: June 16, 2023, 04:36:24 AM »
One is located on the passenger side inside the cowl vent area. Look down into the cowl area beneath the cowl panel louvers and above the heater box.
« Reply #5 on: June 16, 2023, 01:04:34 PM »
Pictures of where to look HERE.
Jonesy
  • 1969 Camaro z28
« Reply #6 on: June 25, 2023, 10:16:58 PM »
Was bid to $55,000, reserve not met. Wow.
1969 Z28 Azure Turquoise
