Author Topic: NEGITIVE BATTERY CABLE LEAD LOCATION  (Read 2993 times)
ALLZS
« on: May 04, 2023, 06:41:02 PM »
on a early build 3 week of sept 68 where is the small wire off the negative battery cable mounted  to is it  the fender or the core support
ALLZS
Re: NEGITIVE BATTERY CABLE LEAD LOCATION
« Reply #2 on: May 04, 2023, 08:45:28 PM »
I don't know what battery was in it from the factory
x66 714
« Reply #3 on: May 04, 2023, 10:45:15 PM »
At this point, unless you have original paper work, you kind of have to guess. A group 22F could be used if you want it like it was from the factory or you have to use a group 24 & call it hd battery. I believe these are both discussed in the assm manual....Joe
« Reply #4 on: May 05, 2023, 01:01:00 PM »
Do you have the original core support for the car?
David K
  • Dr. Longblock
« Reply #5 on: May 05, 2023, 01:38:03 PM »
Are you building a concourse restoration?
ALLZS
« Reply #6 on: May 06, 2023, 02:42:47 AM »
I FOUND MY ANSWER IT DOES GET MOUNTED TO THE CORE SUPPORT
