Author Topic: 68 Shoulder Harness  (Read 7806 times)
gms
68 Shoulder Harness
« on: May 02, 2023, 05:08:56 PM »
 Thank you in advance.  I have a Std interior, black seat belt, w/buckle that shows a model# 277. Dated 28th wk of 68. Researching CRG I thought it was a front shoulder harness for coupe, but length of belt measures approx. 21”. Would this be a rear shoulder belt or maybe for a convertible?  Any assistance is appreciated.
Re: 68 Shoulder Harness
« Reply #1 on: May 02, 2023, 05:47:01 PM »
Have you seen this report?
http://www.camaros.org/seatbelt.shtml#tags
Scroll down and it lists the belt numbers and applications.
« Reply #2 on: May 02, 2023, 06:02:43 PM »
From the picture you posted it looks like the belt has been cut. Is it frayed at the end?
gms
« Reply #3 on: May 03, 2023, 02:42:40 AM »
Yes, I had looked at that report prior to posting, and the reason I questioned the length.
I never thought of it being cut off. Good catch. I will compare it to some other belts.
Sometimes it just takes a different view. Thanks for the look.
David K
  • Dr. Longblock
« Reply #4 on: May 03, 2023, 03:00:17 AM »
The webbing should look like this…both sides.
gms
« Reply #5 on: May 03, 2023, 05:20:31 PM »
Thanks David K. Mine has definitely been trimmed.
David K
  • Dr. Longblock
« Reply #6 on: May 03, 2023, 06:40:17 PM »
If you need some, I can give you a used parts vendor information.
gms
« Reply #7 on: May 04, 2023, 12:09:18 AM »
Thanks that may be helpful. I was looking for my original 13A69 front std. seat belts when I came across this belt.
David K
  • Dr. Longblock
« Reply #8 on: May 04, 2023, 12:52:05 AM »
Email Mark. If he doesn't have any, let me know.
« Reply #9 on: May 04, 2023, 01:10:35 AM »
gms
« Reply #10 on: May 04, 2023, 01:38:10 AM »
« Reply #11 on: May 13, 2023, 09:44:45 PM »
the model # would indicate where used as the shoulder model # was different from the seat belt # as was the different model # used i back seats.
gms
« Reply #12 on: May 16, 2023, 02:25:49 AM »
Since we’re on the topic of seat belts. My research is not coming up with a # 1902
69 Camaro (716- Blue) Deluxe Seat belts. 2-1952 - Front Lap, 1-1914 - Front shoulder, 2-1902 shown with small buckle. Is this rear shoulder belts…?. Dated early 69. (34th wk, 68). Would like to determine RPO for this set. The only cover I have, had both a 1952 and 1902 together if that helps.
« Reply #13 on: May 16, 2023, 01:58:16 PM »
Did you click on the link that Bryon (bcmiller) posted above?  Send a full size photo and I will try to post it as your photo is too hard to see due to size.
69 Deluxe
1907 - Front lap
1952 - Front shoulder
1914 - Rear lap (early)
TBD - Rear Shoulder
I THOUGHT 1902 was deluxe rear shoulder but don't quote me.
gms
« Reply #14 on: May 16, 2023, 04:33:34 PM »
Yes, I checked the CRG link first thing. It shows TBD for rear shoulder belt. Reading some of the other post makes me think rear shoulder belts.
Looking at this thread, I probably should have started a new one. I will try to upload a full size pic.
